2017-08-11, 19:42
I'm trying to run PVR WMC on a LibreELEC 8.0.2 system. This is a new system (NUC). ServerWMC is on a Win 7 VM (firewall off) on my network and is set to run as a service, When I start Libreelec I get:
"add-on couldn't be loaded" "an unknown error has occurred"
After if I try to run TV I get PVR Manager is starting but it stays at 0%.
I've tried with PVR WMC using the sever name (htserver) and its IP (10.2.1.4)
I have a Openelec system and a Kodi system that connect without issue. Reading the logs show that the server (htserver 10.2.1.4) is down, however it is up.
If I SSH into the libreelec system I can ping the server and telnet to it. See below:
SpareBR:/ # ping htserver
PING htserver (10.2.1.4): 56 data bytes
64 bytes from 10.2.1.4: seq=0 ttl=128 time=0.560 ms
64 bytes from 10.2.1.4: seq=1 ttl=128 time=0.386 ms
64 bytes from 10.2.1.4: seq=2 ttl=128 time=0.425 ms
^C
--- htserver ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 0.386/0.457/0.560 ms
SpareBR:/ # telnet htserver 9080
hello
Connection closed by foreign host
SpareBR:/ #
^C
hello
SpareBR:/ #
