Can someone explain this (because obviously Im not getting anywhere. Im running into an issue where I cant find "getMouseRawPosition" Also, This will not work since its so old: I dont know where the XBMC files are on Krypton 17.3
http://arendwierks.blogspot.nl/p/touchsc...i.html?m=1
Please help me.
have you tried the plugin?
Have you tried calibrating using the normal rpi tools?
(2017-08-13, 01:04)nickr Wrote: [ -> ]have you tried the plugin?
I have been trying for months. I can get accurate calibration in Raspbian, and on my PC. Im having the same problem as a whole bunch of people, where the calibration is off and set in the upper left corner only.
Which plugin are you referring to?
raspberry pi has its own native tools to calibrate your touch screen.
