Full Version: Lirc dilema?
Hey guys not often im stumped but i have a real problem.
I cant run the reconfigure command on Lirc as it stopped working so i removed it and all corresponding directories for a fresh start and im getting this:
derek@dungeon:/$ sudo apt-get install -y lirc
Reading package lists... Done
Building dependency tree
Reading state information... Done
Suggested packages:
lirc-compat-remotes lirc-drv-irman lirc-doc lirc-x ir-keytable
Recommended packages:
gir1.2-vte
The following NEW packages will be installed
lirc
0 to upgrade, 1 to newly install, 0 to remove and 0 not to upgrade.
Need to get 407 kB of archives.
After this operation, 2,036 kB of additional disk space will be used.
Get:1 http://gb.archive.ubuntu.com/ubuntu zesty/universe amd64 lirc amd64 0.9.4c-9 [407 kB]
Fetched 407 kB in 0s (1,031 kB/s)
Selecting previously unselected package lirc.
(Reading database ... 463492 files and directories currently installed.)
Preparing to unpack .../lirc_0.9.4c-9_amd64.deb ...
Unpacking lirc (0.9.4c-9) ...
Setting up lirc (0.9.4c-9) ...
cp: cannot stat '/etc/lirc/lircd.conf.dist': No such file or directory
cp: cannot stat '/etc/lirc/lircmd.conf.dist': No such file or directory
cp: cannot stat '/etc/lirc/irexec.lircrc.dist': No such file or directory
cp: cannot stat '/etc/lirc/lirc_options.conf.dist': No such file or directory
Listing '/usr/lib/x86_64-linux-gnu/python3/dist-packages/lirc/'...
Compiling '/usr/lib/x86_64-linux-gnu/python3/dist-packages/lirc/baseview.py'...
Compiling '/usr/lib/x86_64-linux-gnu/python3/dist-packages/lirc/choosers.py'...
Compiling '/usr/lib/x86_64-linux-gnu/python3/dist-packages/lirc/config.py'...
Compiling '/usr/lib/x86_64-linux-gnu/python3/dist-packages/lirc/database.py'...
Compiling '/usr/lib/x86_64-linux-gnu/python3/dist-packages/lirc/mvc_control.py'...
Compiling '/usr/lib/x86_64-linux-gnu/python3/dist-packages/lirc/mvc_model.py'...
Compiling '/usr/lib/x86_64-linux-gnu/python3/dist-packages/lirc/mvc_view.py'...
Compiling '/usr/lib/x86_64-linux-gnu/python3/dist-packages/lirc/util.py'...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for systemd (232-21ubuntu5) ...
Processing triggers for man-db (2.7.6.1-2) ...
When i tried to run the reconfigure it was displaying the lines above about recompiling something.
Really stuck - this PC is an oldie from 2005 with a core 2 duo and a 750ti Nvidia and has NEVER failed me so far so i know its not hardware there must be some software problem - im running the latest ubuntu dev build.
Any help appreciated - and i did read about patching the kernel but long time since i rebuilt a kernel from scratch or such like.
Cheers
Derek
Anyone, help would be appreciated this my little ones link to TV and it keeps him from his Xbox and watching some mind enhancing stuff rather than mind numbing forza 3 Smile but he needs his remote.
Its kind of working again but only certain controls please anyone. thanks derek
When i try to reconfigure i get this:
derek@dungeon:/etc/lirc$ sudo dpkg-reconfigure lirc
Warning: Stopping lircd.service, but it can still be activated by:
lircd.socket
getting lots of errors no matter what i do
https://git.kernel.org/pub/scm/linux/ker...=v4.13-rc3
4.13.0-rc4 kernel and newer have fix.
Sounding like a noob even though i've used linux for many years i havent played with kernels since slackware is there an easy way to do this as i'd like to get my sun involved and if its in the link i appologise i just noticed it thanks for getting back to me.
Derek
Had a quick look can you tell me how to patch that please pal?
Im just running vmlinuz -> boot/vmlinuz-4.10.0-32-generic
Or is there even a way to jump forward to a working version, just my hardware never seems anything other than the generic kernels.
Anyone point me to some instructions to get this fix merged it seems im a fair few kernels behind where the fix lies.
What version of which distro are you running?
Kind of hard to offer you pointers on changing the kernel if we don't at least know that much. You seem to be running a Debian variant (apt-get) but you make mention of Slackware so it's a bit hard to guess at it.
kernel boot/vmlinuz-4.10.0-32-generic
on ubuntu latest test version (6monthly build)
I said i hadnt reconmpiled kernels since slackware which was many years ago when we run one of the first ISP's in Aberdeen Scotland. using Solaris/Irix and slackware.
any other info you need just ask ive read a lot tonight but some of the documentation seems to contradict its self?!?!
trying an an ap called akku
cheers nick but no use lirc is still borked regardless of kernel UKUU is an easy to use tool if you cant be bothered with the .deb files but my problems have not gone away.
(2017-08-12, 18:45)Derek Wrote: [ -> ]Anyone point me to some instructions to get this fix merged it seems im a fair few kernels behind where the fix lies.
Only 4.12-* to <4.13-rc3 kernels need that lirc fix, older and newer should be good.
