I'm trying to import my MP3's into the library, but it kills XBMC!
Here is my logfile.
What I tried:- chmoded -R 755 the MP3 folder
- chowned -R zAo the MP3 folder
- removed the settings folder and tried again
I use OSXBMC 0.1.6 on an iMac 20" with Leopard 10.5.2
Doesn't look as though it's having a problem with death of XBMC from the log, but the exceptions in loading the thumbs is an issue that needs fixing.
Looks like an issue with the osx version of cximage. You don't happen to be able to try it on win32/xbox/linux for comparison do you?
elan may benefit from a copy of one of those mp3s perhaps.
Cheers,
Jonathan
jmarshall Wrote:Doesn't look as though it's having a problem with death of XBMC from the log, but the exceptions in loading the thumbs is an issue that needs fixing.
Cheers,
Jonathan
Haven't tried it on Linux/Win32 but I used to import them on my Xbox.
I will share a mp3 if needed.
OK. Found it.
I was filling in the bug report and noticed that I had one MP3 file twice (the last one mentioned in the logfile). I had a MP3 and a WMA version of it.
Removed the WMA version and now the import goes well.
Thanks and sorry for the time it took!
That's still a bug! Please provide WMA version so we can check + fix it.
