Full Version: Videos | Files
I use the Videos | Files menu option to play movies. I find it much easier to find things since I have everything organised in alpha folders.
I like the fact that the side panel displays the plot and tag. I'd like to also be able to display the data last viewed. Currently I'm fudging it by using a samll program on my Windows PC to update column c03 in the movies table (ie the tag column) using data from the files table. It works but it would be much nicer if I could just set the display to use the information from the files table.
Is there a way of doing that?
