Custom home entries are a really nice touch but if you don't have one default one enabled it looks like this
When a tv guide entry doesn't have a sub-title (mostly movies) it just shows "No further show information available" is it possible just to leave it blank, it looks a bit weird especially when you're watching a channel
1-> Oops, will be fixed later this day.
2-> It looks more weird if there is an empty space.
Edit:
Should be fixed.
I tried the skin on my PC and was impressed how nice it looks and therefore I wanted to install it on my FTV-Stick.
Unfortunately, I can't find the skin on your Repo.
I am using SPMC 16.x, so Jarvis and not Krypton.
Might that be the problem why I can't install it on my FTV-Stick?
Yep, Krypton is required.
(2017-12-24, 07:38)sualfred Wrote: [ -> ]2-> It looks more weird if there is an empty space.
Empty space would look better than "No further show information available" like it is in the guide it self
This looks fine
This
And this doesn't
Movie entries will never have a sub-title in the guide as it will always be the tv shows episode name there
That's not valid for Germany. The providers use the episode value for the genre or a tag line. The info field is used for 95% of all available EPG data here. But I could add the default genre info field as fallback.
(2017-12-24, 13:54)sualfred Wrote: [ -> ]Yep, Krypton is required.
Thanks for the feedback and for providing such a nice Skin.
Merry Christmas! ;-)
(2017-12-24, 15:36)sualfred Wrote: [ -> ]That's not valid for Germany. The providers use the episode value for the genre or a tag line. The info field is used for 95% of all available EPG data here. But I could add the default genre info field as fallback.
I use Schedules Direct so it would be xmltv standards that's probably why, genre as a fallback sounds pretty good. Happy Christmas too
Ok, I'll use genre as fallback.. after the holidays
Happy holidays to you guys too. And to all the others.
Let him fall, let him fall, let him faaaaaalll. Yippie Ka Yay Motherf***er.
It's only Christmas when Hans Gruber falls from the roof of Nakatomi Plaza.
Happy Holidays to everyone.
Happy Holidays, sualfred. Thanks for all the hard work you've been putting up.
Cheers.
The font is too small. Can you add an Arial fontset? GBK characters can't display with the skin.
No, to a bigger font. If you have a smaller TV or a long distance to your monitor, I suggest you to use another skin. And I stopped adding other fonts because of the strange letter/line height handling of it, sorry. It's always a pain to support them.
hy sualfred great skin looks realy great and run smoth on my nvidia shield
i have a little question tv tunes a supported in the tv shows but not in movies is that right and when yes can you please ad it for movies to ?
