Anyhow, it's no big deal for me. Just a little ocd. But it works at least. I do have slow internet so maybe that's the reason. Thx for keeping up with us.
For me, personally, I don't think it's connection or ISP related.
I am on a 1000Mbps/1000Mbps connection, my ISP is also where I work ;P
I'm more inclined to believe the API is experiencing (heavy) load.
I'll try again tomorrow or later this week.
Thanks for all the help!
wow, congratulations
the embuary skin at the Beta stage
thx for the hourly update this skin!
It's in the Beta since dozens of weeks, I just forgot to change the flag
Good day,.. i have question. When scrolling through widgets, either right or left, would be neat if when I pressed the back button on my remote, it would automatically go back to the beginning. It's great it stays in one place, but sometimes I scroll all the way back by holding the back button. But would be a nice feature pressing back=start of widget.
Good idea. Will be included in the next version. But please keep in mind that this won't work inside of library views or dialogs. Only in home and hubs.
(2018-05-03, 09:33)sualfred Wrote: [ -> ]Only in home and hubs
It works fine on home but not in any of the hubs
EDIT: When i press back while at the end of a widget it just brings me to home
14:56:25.023 T:4095384016 DEBUG: OnKey: long-right (0x100f083) pressed, action is Right
14:56:25.071 T:4095384016 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
14:56:25.071 T:4095384016 DEBUG: OnKey: long-right (0x100f083) pressed, action is Right
14:56:25.171 T:4095384016 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
14:56:25.708 T:4095384016 DEBUG: Keyboard: scancode: 0x9e, sym: 0x0008, unicode: 0x0000, modifier: 0x0
14:56:25.708 T:4095384016 DEBUG: OnKey: backspace (0xf008) pressed, action is Back
14:56:25.708 T:4095384016 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
14:56:25.966 T:4095384016 DEBUG: ------ Window Deinit (Custom_1121_TVShowHub.xml) ------
14:56:25.987 T:4095384016 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
14:56:25.987 T:4095384016 DEBUG: ------ Window Init (Home.xml) ------
14:56:26.042 T:4095384016 DEBUG: Keyboard: scancode: 0x9e, sym: 0x0008, unicode: 0x0000, modifier: 0x0
I'm a bit confused as to why this is necessary.
Couldn't all of this be achieved by pressing the "home" button on the keyboard or by adding a custom keymap for those that use a remote/gamepad?
Hmm yes. It only works in home, because there is a window in the "window history". Sorry. All you can do is to map a button with "action(firstpage)" on your remote. Or if you use a keyboard -> Press the Pos1 key.
1. I have kiosk mode enabled but the icon for changing view modes are still visible in my libraries. It also shows up in a couple of other windows. In the "next aired" addon it does nothing when I click it. Bug?
2. A suggestion:
When using the scrollbar (poster view) to scroll all the way to the top, could pressing "up" do nothing instead of the current behaviour where it highlights the far right icon of the top bar?
Pressing down after ending up there only adds to the somewhat confusing behaviour by highlighting the alphabet strip.
Any chance of slightly increasing the size of the logo when playing an episode
Your one looks bigger because emby crops and removes the transparent parts from it
Krismyklebust
Will be changed.
Next aired works for me. Please check if your addon is working.
komplex
Nope, because this skin is targeted to Emby users. Increasing will result in gigantic logos for Emby users.
how to remove or hide this
