I mentioned in post #937 that "Favourites" are not working. Shortly after I posted that, you said it was fixed, but is it though..?
I'm having the same issues as back then. It hasn't been working for a couple of weeks now.
Is working for me. Reset the widget again, I made a template for it. No need to create a custom widget.
Hmm. How do I do that exactly?
Just to clarify, I'm talking about the "Favourites" in the top menu bar.
I don't get what you mean. Please describe exactly what does not work.
Ok, here's an example:
1. Highlight an item (movie/tv show/episode). Press "c" to bring up the context menu and navigate to Emby options -> Add to favorites.
2. In the top menu bar of Embuary, next to "search", "genres" etc, there's a "Favourites" shortcut where I would expect to see the newly added favourite, alas it's not there...
3. If I open up Emby in a web browser I can see the newly added favourite.
That's a problem of the addon, not of the skin.
Edit:
But it works on my end
Just noticed the PVR video OSD doesn't have a a subtitle button like the regular video OSD
Yeah a lot of UK sat provide subtitles
Think this is a Leia bug, it shows the audio bitrate on channel change similar to when you have music playing
The image was from the nightly on the 24th just updated to last nights one and it's still there. Guessing the bug is back or it's a new one if it was fixed
I'm not facing it with TV Headend as backend.
You better should report it on
https://trac.kodi.tv/ incl. debug log, screenshots and maybe a screen recording.
Linking to the PR from above also doesn't hurt.
From the thread you linked in that PR FernetMenta seemed adamant that it was a tvh issue, i use MediaPortal and i can't be arsed going back and forward with him about it so i'll just live with it for now and hopefully it gets fixed in the future lol
No bug report, no issue. Just mention that it has the same symptom -> The vizualisation window kicks if.
Edit:
I'm not quite sure if it's the vizualisation. But there is a race condition somewhere.
