I'm running Linux Mint 18.2 with Kodi 17.3. I've run into this with multiple fresh installs. When I start Kodi after a fresh install, I'll install video addons from the official repositories. YouTube, ABC, etc. After one or two....maybe three...install, the next one will stay at 0% downloading forever. If I go to install another addon, that will get stuck at zero. When I attempt the next one, Kodi crashes. After this the first few addons will not function. The only way to install addons is to continually delete the addons27 file in database. Then its a rinse and repeat operation until you have all the addons you want. Here's the kicker I recently found out.....the addons will stop working anyway.
I am utterly perplexed at what is causing this issue. It looks like a curl timeout issue but I have no clue on how to fix it.
And after 82 posts, we're slightly perplexed that you haved provided us with a debug file yet. Who knows what we'll find
Running Ubuntu 16.04.2 here, addons install and work okay. Apparently Mint is working differently at some point.
(2017-08-19, 15:55)Klojum Wrote: [ -> ]And after 82 posts, we're slightly perplexed that you haved provided us with a debug file yet. Who knows what we'll find
Sorry, I didn't even think about that. I'm out of it atm.
https://pastebin.com/22bRUaUj
Is there way you can help me, my downloader app on my fire stick, when I click on it it says; the app I am looking for can be found.
Quote:the app I am looking for can be found.
So what is the problem then?
Did you guys find anything?
(2017-08-21, 19:58)Borg-101 Wrote: [ -> ] (2017-08-19, 15:55)Klojum Wrote: [ -> ]And after 82 posts, we're slightly perplexed that you haved provided us with a debug file yet. Who knows what we'll find
Debugging was not enabled.
22:30:37.475 T:140395469347136 NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:30:37.475 T:140395469347136 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
