Full Version: slow loading
Hi all,
i have bee using Jarvis on my fire tv for a while, it works well.
the only issue i have is that when i start Kodi, it take a long time for it to show all the files.
about 30 to 40 seconds. is this normal?
once the files have been loaded it works PERFECT. No buffering ONLY slow load times when kodi first start ups
can i reduce the loading times? i have about 600 Movies.
i use My sql for the library, to keep my to fire tv and PC in sync.
Thax for your help
any one??
There is no crystal ball available in the foreseeable future.
Ergo, please start with providing a debug log.
A bit off topic, but if you are looking to keep your library in sync between multiple devices you might also want to look at something like plex and the plex kodi connect add-on.
(2017-08-22, 20:14)Klojum Wrote: [ -> ]There is no crystal ball available in the foreseeable future.
Didnt there use to be a skin named Chrystal or stg along those lines? Maybe that skin had such ball...
