Full Version: Music play - audio codec information
Hi
Is there are way of establishing the audio stream properties during music play?
I find to enjoy music more when assured that the audio is of high quality Tongue
moved to music
Currently no technical info about songs is stored in the music database, so all you can get is an indication from the file extension (mp3, flac, and so on). However, once playback is started technical details are available for display by a skin:
BitRate
Channels
BitsPerSample
SampleRate
Codec
scott s.
(2017-08-25, 01:36)scott967 Wrote: [ -> ]Currently no technical info about songs is stored in the music database, so all you can get is an indication from the file extension (mp3, flac, and so on). However, once playback is started technical details are available for display by a skin:
BitRate
Channels
BitsPerSample
SampleRate
Codec
scott s.
Yes, I am after the during play information - how do I get it to show? Do I need a specific skin type?
Which skin are you currently using?
(2017-08-25, 23:41)Karellen Wrote: [ -> ]Which skin are you currently using?
I am using Confluence..., do not like the others much.
Now that we all learned that skins can read the audio stream parameters - is there a skin that takes advantage of that and actually show the info?
Nox 5 Silvio, titan, madnox, aeonmq, mimic, and so on Smile
But if you need to see the different, and can't hear it, it doesn't really matter ;P
I've done some work on that for my Aeon MQ5 Leiamod, you might also check out Aeon MQ 7 and its mods (for Krypton or Leia), shows it a little differently. It seems to me it would be more useful to have audio quality available as a filter, but that would mean a database change to extract and save the details (like streamdetails for video).
scott s.
(2017-09-06, 00:44)scott967 Wrote: [ -> ]It seems to me it would be more useful to have audio quality available as a filter, but that would mean a database change to extract and save the details (like streamdetails for video).
Yes, I agree. On my todo list and likely for v18 Smile
