Full Version: ArgusTV removed from current Kodi 18 alpha
Pages: 1 2 3 4
Thanks to everyone involved in getting the Argus TV addon working in Kodi 18.
It works well for me apart from one issue I'm having... I can play recordings fine but when I open a channel via the Channels list or EPG, it plays back with no sound and a jerky picture. I've had debug logging on and the CPU and framerate figures are all fine. Has anyone else had this issue? It happens on a Windows laptop and a HTPC (Kodi and Argus TV both running on the same machine) I use, and changing the refresh rate doesn't affect it.
I've posted a log to Pastbin in case it helps figure things out: https://pastebin.com/S40CKyp7
(2017-12-11, 22:30)botchla Wrote: [ -> ]Thanks to everyone involved in getting the Argus TV addon working in Kodi 18.
 I have sound and good quality video in live channels, so no issue for me (tested with 18.0-ALPHA1 Git:20171212-e967f20 x64 in windows). Maybe you touch other settings or have a bad Nightly build.
I get exactly the same, no sound on switch to from "Guide" or "Channels" list and jerky (until I skip back a few seconds. But as soon as I record and watch from recordings, then all is OK Huh
I noticed the ArgusTV PVR client has again been removed from the last 2 Nightly releases of Kodi 18 (8th & 9th April). I've reverted to the last working version from 5th.
Is anybody aware if this is just a short term issue or something that is likely to stay unresolved ?
Cheers
(2018-04-09, 16:12)i0zjh02 Wrote: [ -> ]I noticed the ArgusTV PVR client has again been removed from the last 2 Nightly releases of Kodi 18 (8th & 9th April). I've reverted to the last working version from 5th.
Cheers
Thanks for the headsup. ARGUS TV client should again be available with next build.
(2018-04-09, 17:06)ksooo Wrote: [ -> ]
Cheers
 Thanks :-) it is indeed working again in this mornings build !!
Thank you - this is critical!!!
Pages: 1 2 3 4
