Full Version: Mouse cursor?
Hi just switched to OSX on a hackintosh running leopard 10.5, I downloaded the latest dmg file from here http://dn-0.com/xbmc-trac/wiki/WikiStart
I then installed this XBMC-0.1.7.dmg (40.4 MB) - added by leafmuncher 2 days ago.
In linux I had a mouse cursor in xbmc, but in osx i do not have a cursor full screen or not!!!!
What am I missing?Big Grin
AJ
ajgoyt Wrote:Hi just switched to OSX on a hackintosh running leopard 10.5, I downloaded the latest dmg file from here http://dn-0.com/xbmc-trac/wiki/WikiStart
AJ
Possible "hackintosh" issue? I don't get a mouse in full screen but do in when OSXBMC is in window mode.
Correct - in small window mode I have a cursor untill I sweep it over the XBMC window, Then it goes away. In full screen I have no cursor!
This must be normal? In Linux XBMC in small and full screen i have a cursor!
Rolleyes
AJ
ajgoyt Wrote:Correct - in small window mode I have a cursor untill I sweep it over the XBMC window, Then it goes away. In full screen I have no cursor!
Rolleyes
AJ
Do you have Settings > Appearance > Look & Feel > Enable Mouse enabled?
jeremymc7 Wrote:Do you have Settings > Appearance > Look & Feel > Enable Mouse enabled?
Now i do thanks.....Cool
