Full Version: Playing music files in endless loop
Hello,
How can I make Kodi (16.1) repeat all music files in a folder? That is restart first file when it finishes the last one?
TIA
I assume you are viewing your music via the "files" node, so you see the actual folders. When you focus on the folder, click "p" to play the entire folder. Assuming you use "Confluence"skin, open the left slide out menu and there is an option to "open playlist". Click that, brings up the music playlist window. Again open the left slide out menu and now you see there is a spinner that allows you to repeat none / one / or all. Select all. You can also shuffle the playlist if you want.
scott s.
That worked. TYVM.
