Full Version: Changing configuration files doesn't work
Hi all!
I have 2 problems with RssFeeds.xml and Keymap.xml:
  • RssFeeds.xml
    I've changed the URL of the feed, but when I run XBMC nothing happens: it shows the default feed again.
  • Keymap.xml
    I'm using the Apple Remote and I want to use the plus/minus button to raise/lower the volume when viewing a video. I tried to change the settings from this
    <FullscreenVideo>
        <keyboard>
          <up>BigStepForward</up>
          <down>BigStepBack</down>
        </keyboard>
    </FullscreenVideo>
    to this:
    <FullscreenVideo>
        <keyboard>
          <up>[color=Red][b]VolumeUp[/b][/color]</up>
          <down>[color=Red][b]VolumeDown[/b][/color]</down>
        </keyboard>
    </FullscreenVideo>
    Again, running XBMC nothing changed...
    Is <keyboard> the right section for the Apple Remote?
Am I missing something?
I open del xml file, edit, save, close the texteditor and run XBMC...
Smile
up! Smile
i would also like to know if the apple remote keymap is user editable in the 0.1.7 release? want to make a button goto projectm when music is on.
ilboso Wrote:Hi all!
Make sure you're modifying the file in ~/Library/Application Support/XBMC/UserData/.
Quote:I'm using the Apple Remote and I want to use the plus/minus button to raise/lower the volume when viewing a video.
Sorry, remapping keys with the Apple Remote is not yet supported.
Thanks,
-elan
@elan:
thanks for your replies! I was looking in the wrong folder... now the RSS works!
Smile
How come the software run properly, but there is no folder in 'Application support' Huh
Means , I can't change configuration??
please advice,
Tomer
