2017-08-29, 18:53
My television provider (Ziggo, The Netherlands) recently launched an HTML5 based website to watch live TV, replay TV, EPG as well as a VOD section. I created a prootype add-on that allows you to play the VOD movies and series (using Kodi 18's DRM feature, with some invaluable help from peak3d) and now I would like to also open up the TV related content. I believe the way to go is to create a PVR client ... but that's just about how far I got. Documentation seems to be, erm, underwhelming, and as far as I understand the API is going through some changes. To be honest, I don't know where to start. Therefore, some questions to the good community of Kodi developers:
- Is a PVR client indeed the way to go?
- Is there a tutorial/example for a simple PVR client?
- Where can I find current documentation?
- Do I need to develop the client in C (didn't write C in 20 years) or can I use Python so I can re-use the code I wrote for the VOD add-on? I saw some Python implementation of the API, but I'm not sure if it is up to date.
- How do I setup my development environment? I use Eclipse for Java, web frontend, and now Python as well - what do Kodi PVR client developers use?
