2017-08-30, 02:09
2017-08-30, 03:23
Unfortunately not. Really wish you could at least get it in skin settings as it would be nice to be able to provide different levels of settings.
2017-08-30, 05:05
heck then you could use it through out the skin for different menus could change based on this setting , heck even add one more to the roll for kiosk. just to keep thing uniform through out the windows.
2017-08-30, 06:53
It is saved in guisettings.xml so I imagine it would be pretty easy to write a simply python script to retrieve it
It is under <general> <settinglevel> and has a numeric value with 3 being expert.
2017-08-30, 11:31
Had not thought of that but for that to work the skin setting would have to update instantly as u click thru the choices...
I ended up doing something else to get the effect I was after thanks for trying.
