I have a software PCM plugin for alsa which is showing up with
but not
as it is not a hardware soundcard. How can I get it to show up in the System -> Audio Source dropdown in Kodi?
I can use it like this:
aplay -D myAudioDevice -f cd test.wav
Recompile kodi and change AESinkALSA
Hi Fritsch,
thanks for you reply. Could you give me a hint what I need to adjust to make it happen? My initial analysis led me here:
Github Kodi EnumerateDevice
But I am not sure about what exactly I need to adjust to make software pcm's visible.
/* Ubuntu has patched their alsa-lib so that "defaults.namehint.extended"
* defaults to "on" instead of upstream "off", causing lots of unwanted
* extra devices (many of which are not actually routed properly) to be
* found by the enumeration process. Skip them as well ("hw", "dmix",
* "plughw", "dsnoop"). */
else if (baseName != "default"
&& baseName != "sysdefault"
&& baseName != "surround40"
&& baseName != "surround41"
&& baseName != "surround50"
&& baseName != "surround51"
&& baseName != "surround71"
&& baseName != "hw"
&& baseName != "dmix"
&& baseName != "plughw"
&& baseName != "dsnoop")
EnumerateDevice(list, name, desc ? desc : name, config);
Remove the baseName that matters yours from the above list.
Thank you so much fritsch! It worked
