2017-09-01, 21:06
2017-09-02, 04:34
(2017-09-01, 21:06)tjost Wrote: [ -> ]Hi,Without you being more specific...
where do I find the OSDRepeatOffOF.png? Or the Value in a .xml.
It
I suggest to check variables.xml for MusicOSDRepeatButtonVar.
I think that is what you are looking for but without some more info I am just guessing
2017-09-02, 12:51
Yes I did this.
So repeat one focus/no focus
repeat all Focus/no focus
And repeat off no focus
But on focus it dosent show an icon
2017-09-05, 00:31
Maybe something in your code then...
Would need to see the whole xml and VAR to help.
2017-09-06, 12:23
PHP Code:
<?xml version="1.0" encoding="UTF-8"?>
<window>
<defaultcontrol always="true">602</defaultcontrol>
<coordinates>
<system>1</system>
<left>0</left>
<top>0</top>
</coordinates>
<controls>
<control type="group">
<animation effect="slide" end="0,-238" time="240" tween="quadratic" condition="Window.IsVisible(selectdialog) | Window.IsVisible(script-cu-lrclyrics-main.xml)">Conditional</animation>
<animation effect="slide" start="0,-238" end="0,0" time="240" tween="quadratic">WindowOpen</animation>
<animation effect="slide" end="0,-238" start="0,0" time="240" tween="quadratic">WindowClose</animation>
<control type="image">
<width>100%</width>
<top>0</top>
<height>61</height>
<texture>darky.png</texture>
</control>
<control type="grouplist" id="202">
<top>0</top>
<left>35</left>
<height>60</height>
<width>100%</width>
<align>center</align>
<scrolltime tween="sine">200</scrolltime>
<orientation>horizontal</orientation>
<onup>706</onup>
<ondown>802</ondown>
<onleft>202</onleft>
<onright>202</onright>
<control type="button" id="802">
<texturefocus>audiobutton/rate_focus.png</texturefocus>
<texturenofocus>audiobutton/rate.png</texturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
<onclick>SetRating</onclick>
</control>
<control type="button" id="700">
<texturefocus>audiobutton/playlist_focus.png</texturefocus>
<texturenofocus>audiobutton/playlist.png</texturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
<onclick>Close</onclick>
<onclick>ActivateWindow(MusicPlaylist)</onclick>
</control>
<control type="button" id="500">
<texturefocus>audiobutton/visu_focus.png</texturefocus>
<texturenofocus>audiobutton/visu.png</texturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
</control>
<control type="button" id="702">
<texturefocus>audiobutton/settings_focus.png</texturefocus>
<texturenofocus>audiobutton/settings.png</texturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
<onclick>Addon.Default.OpenSettings(xbmc.player.musicviz)</onclick>
<visible>Visualisation.Enabled</visible>
</control>
<control type="button" id="705">
<texturefocus>osd/buttons_white/OSDVideoFO.png</texturefocus>
<texturenofocus>osd/buttons_white/OSDVideoNF.png</texturenofocus>
<width>60</width>
<height>60</height>
<font />
<onclick>ActivateWindow(visualisationpresetlist)</onclick>
<visible>Visualisation.HasPresets</visible>
</control>
<control type="button" id="600">
<texturefocus>audiobutton/back_focus.png</texturefocus>
<texturenofocus>audiobutton/back.png</texturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
<onclick>PlayerControl(Previous)</onclick>
</control>
<control type="button" id="601">
<texturefocus>audiobutton/fastback_focus.png</texturefocus>
<texturenofocus>audiobutton/fastback.png</texturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
<onclick>PlayerControl(Rewind)</onclick>
</control>
<control type="togglebutton" id="602">
<texturefocus>audiobutton/pause_focus.png</texturefocus>
<texturenofocus>audiobutton/pause.png</texturenofocus>
<alttexturefocus>audiobutton/play_focus.png</alttexturefocus>
<alttexturenofocus>audiobutton/play.png</alttexturenofocus>
<label />
<altlabel>208</altlabel>
<width>60</width>
<height>60</height>
<font />
<usealttexture>Player.Paused | Player.Forwarding | Player.Rewinding</usealttexture>
<onclick>PlayerControl(Play)</onclick>
</control>
<control type="button" id="603">
<texturefocus>audiobutton/stop_focus.png</texturefocus>
<texturenofocus>audiobutton/stop.png</texturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
<onclick>PlayerControl(Stop)</onclick>
</control>
<control type="button" id="604">
<texturefocus>audiobutton/fastforward_focus.png</texturefocus>
<texturenofocus>audiobutton/fastforward.png</texturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
<onclick>PlayerControl(Forward)</onclick>
</control>
<control type="button" id="605">
<texturefocus>audiobutton/forward_focus.png</texturefocus>
<texturenofocus>audiobutton/forward.png</texturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
<onclick>PlayerControl(Next)</onclick>
</control>
<control type="button" id="703">
<texturefocus>audiobutton/lyrics_focus.png</texturefocus>
<texturenofocus>audiobutton/lyrics.png</texturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
<onclick>RunScript(script.cu.lrclyrics)</onclick>
</control>
<control type="togglebutton" id="704">
<texturefocus>audiobutton/shuffle_off_focus.png</texturefocus>
<texturenofocus>audiobutton/shuffle_off.png</texturenofocus>
<alttexturefocus>audiobutton/shuffle_on_focus.png</alttexturefocus>
<alttexturenofocus>audiobutton/shuffle_on.png</alttexturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
<usealttexture>Playlist.IsRandom</usealttexture>
<onclick>PlayerControl(Random)</onclick>
</control>
<control type="button" id="707">
<width>0.1</width>
<height>0.1</height>
<texturefocus />
<texturenofocus />
<label>$LOCALIZE[486]$INFO[Playlist.Repeat, : ]</label>
<font />
<onclick>PlayerControl(Repeat)</onclick>
</control>
<control type="image" id="708">
<texture>$VAR[MusicOSDRepeatButtonVar]</texture>
<alttexturefocus>audiobutton/repeat_off_focus.png</alttexturefocus>
<width>60</width>
<height>60</height>
</control>
<control type="button" id="706">
<texturefocus>audiobutton/skin_focus.png</texturefocus>
<texturenofocus>audiobutton/skin.png</texturenofocus>
<label />
<width>60</width>
<height>60</height>
<font />
<onclick>Dialog.Close(musicosd)</onclick>
<onclick>ActivateWindow(1120)</onclick>
<onclick>SetProperty(MusicOSD.Settings,True,home)</onclick>
</control>
</control>
</control>
</controls>
</window>
2017-09-06, 12:25
download the AEON minimal Skin from my REPo please
http://mraap.de/kodi
I canĀ“t post the whole Code here.
2017-09-08, 04:17
The anime skin?
Link says it has not been updated since April...
Can you send me a PM of your latest skin version instead. This link/repo just seems a little weird to me
2017-09-15, 06:38
2017-09-15, 10:34
You are missing the repeat_focus.png image in your media/audiobutton folder
2017-09-16, 23:05
Thank you ever so much. This was very helpful.
