(2020-10-16, 05:58)Lunatixz Wrote: [ -> ] (2020-10-16, 05:16)johnnyaywah Wrote: [ -> ]Hi Lunatixz
Long time fan, love your work!
I run KODI on a cople of Nvididia Shield TVs with a HDHOMERUN tuner
Noticed my epg wasnt refreshing and now ive lost it alltogether
I get an error saying uEPG isnt working and to contact you...LOL...could thid be why my EPG is playing up?
what additional information may i provide you? (assuming you still support this addon)
Cheers
Thanks! I believe something broke on HDHomeruns end... I've seen a lot of reports from different sources that guidedata is down.
thanks for the quick reply
I raised a ticket with HDHOMERUN, they asked me to check the epg on the Android app and since that worked, they consider the issue someone elses problem
Thanks for confirming the issue is widespread, ill wait for a software update from them
Is there any way I can change the gray color (outline in red). I have a real issue with my eyes being able to read what's contained there. White on white is not good, at least for me. I'm using Aeon Nox Silvo and wondering if it gets this color from skin? Love the Locast addon but not crazy about the uPEG colors....c'mon make an old guy happy!
(2021-04-28, 17:10)flhthemi Wrote: [ -> ]Is there any way I can change the gray color (outline in red). I have a real issue with my eyes being able to read what's contained there. White on white is not good, at least for me. I'm using Aeon Nox Silvo and wondering if it gets this color from skin? Love the Locast addon but not crazy about the uPEG colors....c'mon make an old guy happy!
Looks like a texture is missing... it shouldn't look like that. Try reinstalling or try a different skin.
BTW Locast development was moved to Matrix and will no longer receive updates. Same with uEPG...
(2021-04-28, 17:52)Lunatixz Wrote: [ -> ] (2021-04-28, 17:10)flhthemi Wrote: [ -> ]Is there any way I can change the gray color (outline in red). I have a real issue with my eyes being able to read what's contained there. White on white is not good, at least for me. I'm using Aeon Nox Silvo and wondering if it gets this color from skin? Love the Locast addon but not crazy about the uPEG colors....c'mon make an old guy happy!
Well I found a way around it! I edited the color codes in the "script.module.uepg.guide.xml" file. I'm a happy camper now.
Thanks for the very, very speedy reply! And yes I am going to set this up in Matrix! But I noticed there was no Guide when I installed it in my portable setup...did I miss something?
(2021-04-28, 18:09)flhthemi Wrote: [ -> ] (2021-04-28, 17:52)Lunatixz Wrote: [ -> ] (2021-04-28, 17:10)flhthemi Wrote: [ -> ]Is there any way I can change the gray color (outline in red). I have a real issue with my eyes being able to read what's contained there. White on white is not good, at least for me. I'm using Aeon Nox Silvo and wondering if it gets this color from skin? Love the Locast addon but not crazy about the uPEG colors....c'mon make an old guy happy!
The guide was moved to Kodi's PVR frontend; uEPG no longer required. Install "IPTV Manager" and configure Locast to enable integration under settings.
Any further support for locast can be made here:
https://forum.kodi.tv/showthread.php?tid=334947
