I find the audio offset for Kodi 17.4 is not working correctly. When I go into settings to adjust the audio offset the background isn't disappearing so I can see what going on on the screen. I get the foreground, the moving bar that shows you where the offset is but without the background disappearing I can only guess what the offset adjustment is doing. Can this be fixed?
Correct me if i am wrong but i think 17.4 is final and devs moved to 18
(2017-09-11, 00:52)timmins Wrote: [ -> ]I find the audio offset for Kodi 17.4 is not working correctly. When I go into settings to adjust the audio offset the background isn't disappearing so I can see what going on on the screen. I get the foreground, the moving bar that shows you where the offset is but without the background disappearing I can only guess what the offset adjustment is doing. Can this be fixed?
This has not been my experience, use this feature all the time so it's not a universal problem with v17.4
What hardware are you using?
What skin?
Have you installed any non supported modifications to Kodi?
Can you perhaps provide a
Debug log (wiki) or even a short video as an example?
I am experiencing the same thing. The OSD background is not disappearing so it is difficult to change the offset.
I am using nVidia Shield TV with the Aeon MQ7 skin.
(2018-06-03, 19:06)shanester Wrote: [ -> ]I am experiencing the same thing. The OSD background is not disappearing so it is difficult to change the offset.
Unless you can reproduce the issue with Estuary it's not a Kodi issue and you need to report it in the MQ7 sub-forum.
