I switched today from a media portal backend that was giving me all sorts of issues to Argus. In the main it works really well, I was just trying to set-up a timer when I saw the following error -
"Time Rule creation failed, The PVR add-on does not support a suitable timer rule type".
I guess this is an issue with the plugin as I can set timers using the Argus web interface.
Does anyone know if this add-on is still being developed as I see a lot of unanswered threads here and on the ArgusTV forums. If not whats another good PVR option for Kodi with active support?
(2017-09-12, 00:14)sepulchre Wrote: [ -> ]I switched today from a media portal backend that was giving me all sorts of issues to Argus. In the main it works really well, I was just trying to set-up a timer when I saw the following error -
For me, the argustv add-on seems to be dead. There was no active development for years. We just kept it building, no new features, no bug fixes.
EDIT: there are a couple if well maintained PVR add-ons, among them vdr, tvheadend, mythtv to name just a few.
(2017-09-12, 07:57)ksooo Wrote: [ -> ]For me, the argustv add-on seems to be dead. There was no active development for years. We just kept it building, no new features, no bug fixes.
Appreciate the reply ksooo, it's a real shame though as Argus in all other respects is working brilliantly compared to the Mediaportal backend I used to run. I will check out the other backends you listed, but I think these all require linux which I don't have time to learn unfortunately, a windows option is all I can look into right now.
(2017-09-12, 09:50)sepulchre Wrote: [ -> ] (2017-09-12, 07:57)ksooo Wrote: [ -> ]For me, the argustv add-on seems to be dead. There was no active development for years. We just kept it building, no new features, no bug fixes.
That's the way it works with free and open source software. You can't rely on anything. If there is a volunteer who is willing to maintain Argus TV, fine - if not, you have to live with this situation or take action yourself, time and skills permitted ofc.
Beyond hacking together excel VBA my programming skills are unfortunately none existent. If I could help I certainly would, as it is I wouldn't even know where to start, i.e what language is used?
