When I have two versions of the same movie I create a directory called "extras" and there I put the different version. When I give it to rename only folder it starts copying the file of the movie that I have in "extras" inside the main folder of the film so I think it is a bug. My system is mac osx saw. Thanks in advance.
Will have to check, thanks for information.
Usually, all the (video) files stored inside /extras/ are "extras".
You should see them on the mediainformation dialog as such.
This is for plain video files.
If you have made an subfolder for your movie, this is another case
Then this will not be detected as "extra"... but as regular movie...
I have the films in folders and into the folders If I have another version I put into the "extras" subfolder.
By the example:
name of film/extras/nameoffilmanotherversion.ext
I like because I see the files offline. Normally are better versions.
Thanks in advance.
works for me.
Please make a screenshot of your folder, and/or upload logfile after a fresh update...
Hello, thanks in advance.
Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray.iso to /Volumes/BD CINE 123/Equipo paranormal (2013)/Equipo paranormal (2013) [V.O].Blu-ray.iso
2017-09-26 07:26:33,295 INFO [tmmpool-rename-T1] org.tinymediamanager.core.Utils:783 - Successfully moved file from /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray.iso to /Volumes/BD CINE 123/Equipo paranormal (2013)/Equipo paranormal (2013) [V.O].Blu-ray.iso
2017-09-26 07:26:33,296 INFO [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:1282 - copy file /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray-fanart.jpg to /Volumes/BD CINE 123/Equipo paranormal (2013)/Equipo paranormal (2013) [V.O].Blu-ray-fanart.jpg
2017-09-26 07:26:33,296 DEBUG [tmmpool-rename-T1] org.tinymediamanager.core.Utils:839 - try to copy file /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray-fanart.jpg to /Volumes/BD CINE 123/Equipo paranormal (2013)/Equipo paranormal (2013) [V.O].Blu-ray-fanart.jpg
2017-09-26 07:26:33,297 INFO [tmmpool-rename-T1] org.tinymediamanager.core.Utils:887 - Successfully moved file from /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray-fanart.jpg to /Volumes/BD CINE 123/Equipo paranormal (2013)/Equipo paranormal (2013) [V.O].Blu-ray-fanart.jpg
2017-09-26 07:26:33,298 INFO [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:1282 - copy file /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray-poster.jpg to /Volumes/BD CINE 123/Equipo paranormal (2013)/Equipo paranormal (2013) [V.O].Blu-ray-poster.jpg
2017-09-26 07:26:33,298 DEBUG [tmmpool-rename-T1] org.tinymediamanager.core.Utils:839 - try to copy file /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray-poster.jpg to /Volumes/BD CINE 123/Equipo paranormal (2013)/Equipo paranormal (2013) [V.O].Blu-ray-poster.jpg
2017-09-26 07:26:33,302 INFO [tmmpool-rename-T1] org.tinymediamanager.core.Utils:887 - Successfully moved file from /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray-poster.jpg to /Volumes/BD CINE 123/Equipo paranormal (2013)/Equipo paranormal (2013) [V.O].Blu-ray-poster.jpg
2017-09-26 07:26:33,306 INFO [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:1282 - copy file /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray.nfo to /Volumes/BD CINE 123/Equipo paranormal (2013)/Equipo paranormal (2013) [V.O].Blu-ray.nfo
2017-09-26 07:26:33,306 DEBUG [tmmpool-rename-T1] org.tinymediamanager.core.Utils:839 - try to copy file /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray.nfo to /Volumes/BD CINE 123/Equipo paranormal (2013)/Equipo paranormal (2013) [V.O].Blu-ray.nfo
2017-09-26 07:26:33,307 INFO [tmmpool-rename-T1] org.tinymediamanager.core.Utils:887 - Successfully moved file from /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray.nfo to /Volumes/BD CINE 123/Equipo paranormal (2013)/Equipo paranormal (2013) [V.O].Blu-ray.nfo
2017-09-26 07:26:33,308 INFO [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:1282 - copy file /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/extras/Equipo Paranormal 1080p 2013 [tt2272336].mkv to /Volumes/BD CINE 123/Equipo paranormal (2013)/extras/Equipo Paranormal 1080p 2013 [tt2272336].mkv
2017-09-26 07:26:33,309 DEBUG [tmmpool-rename-T1] org.tinymediamanager.core.Utils:839 - try to copy file /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/extras/Equipo Paranormal 1080p 2013 [tt2272336].mkv to /Volumes/BD CINE 123/Equipo paranormal (2013)/extras/Equipo Paranormal 1080p 2013 [tt2272336].mkv
2017-09-26 07:26:36,749 DEBUG [tmmpool-image-download-task-T22] org.tinymediamanager.core.Utils:728 - try to move file /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray-logo.png.part to /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray-logo.png
2017-09-26 07:26:36,751 INFO [tmmpool-image-download-task-T22] org.tinymediamanager.core.Utils:783 - Successfully moved file from /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray-logo.png.part to /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray-logo.png
2017-09-26 07:26:36,753 DEBUG [tmmpool-image-download-task-T22] o.t.core.entities.MediaFile:1657 - start MediaInfo for /Volumes/BD CINE 123/Equipo paranormal (Actividad paranormal) (2013)/Equipo paranormal (Actividad paranormal) (2013) [V.O.].Bluray-logo.png
I still can't see your problem?
copy file
to
You've chosen to rename the folder, this is why the main folder gets renamed.
But your extra is STILL copied into extras folder...?
Usually, when renaming folders, the main folder should only be renamed. Only if this does not work at first place, we see some copy actions...
Would suggest, to cleanup your 2 folders of Equipo paranormal manually, and try again....
Hello,
When it does that it creates a new folder with the name of the movie and creates another folder of extras copying the mkv. I sense that it does when the folder name changes.
Thanks in advance.
Hello,
You can see here something?
Thanks in advance.
2017-09-28 07:39:12,068 DEBUG [tmmpool-image-download-task-T34] org.tinymediamanager.core.Utils:728 - try to move file /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-clearart.png.part to /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-clearart.png
2017-09-28 07:39:12,070 INFO [tmmpool-image-download-task-T34] org.tinymediamanager.core.Utils:783 - Successfully moved file from /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-clearart.png.part to /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-clearart.png
2017-09-28 07:39:12,070 DEBUG [tmmpool-image-download-task-T34] o.t.core.entities.MediaFile:1657 - start MediaInfo for /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-clearart.png
2017-09-28 07:39:12,123 INFO [tmmpool-image-download-task-T34] o.t.c.movie.tasks.MovieExtraImageFetcher:95 - Movie 'Desconexión' is within a multi-movie-directory - skip downloading of CLEARART images.
2017-09-28 07:39:13,291 DEBUG [tmmpool-image-download-task-T35] org.tinymediamanager.core.Utils:728 - try to move file /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-disc.png.part to /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-disc.png
2017-09-28 07:39:13,291 INFO [tmmpool-image-download-task-T35] org.tinymediamanager.core.Utils:783 - Successfully moved file from /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-disc.png.part to /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-disc.png
2017-09-28 07:39:13,292 DEBUG [tmmpool-image-download-task-T35] o.t.core.entities.MediaFile:1657 - start MediaInfo for /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-disc.png
2017-09-28 07:39:13,313 INFO [tmmpool-image-download-task-T35] o.t.c.movie.tasks.MovieExtraImageFetcher:95 - Movie 'Desconexión' is within a multi-movie-directory - skip downloading of DISCART images.
2017-09-28 07:39:13,324 INFO [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:210 - Renaming movie: Desconexión
2017-09-28 07:39:13,324 DEBUG [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:211 - movie year: 2012
2017-09-28 07:39:13,324 DEBUG [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:212 - movie path: /Volumes/BD CINE 123/Desconexión (2012)
2017-09-28 07:39:13,324 DEBUG [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:213 - movie isDisc?: false
2017-09-28 07:39:13,325 DEBUG [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:214 - movie isMulti?: true
2017-09-28 07:39:13,325 DEBUG [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:218 - path expression: $T ($Y) {[$3]}
2017-09-28 07:39:13,325 DEBUG [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:219 - file expression: $T ($Y){ [$3]}{ [$K]}{.$3}.$S
2017-09-28 07:39:13,325 DEBUG [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:239 - movie willBeMulti?: false
2017-09-28 07:39:13,353 DEBUG [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:362 - Our new basename for renaming: Desconexion (2012) [V.O].Blu-ray
2017-09-28 07:39:13,354 DEBUG [tmmpool-rename-T1] org.tinymediamanager.core.Utils:728 - try to move file /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray.iso to /Volumes/BD CINE 123/Desconexion (2012)/Desconexion (2012) [V.O].Blu-ray.iso
2017-09-28 07:39:13,355 INFO [tmmpool-rename-T1] org.tinymediamanager.core.Utils:783 - Successfully moved file from /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray.iso to /Volumes/BD CINE 123/Desconexion (2012)/Desconexion (2012) [V.O].Blu-ray.iso
2017-09-28 07:39:13,355 INFO [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:1282 - copy file /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-fanart.jpg to /Volumes/BD CINE 123/Desconexion (2012)/Desconexion (2012) [V.O].Blu-ray-fanart.jpg
2017-09-28 07:39:13,355 DEBUG [tmmpool-rename-T1] org.tinymediamanager.core.Utils:839 - try to copy file /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-fanart.jpg to /Volumes/BD CINE 123/Desconexion (2012)/Desconexion (2012) [V.O].Blu-ray-fanart.jpg
2017-09-28 07:39:13,362 INFO [tmmpool-rename-T1] org.tinymediamanager.core.Utils:887 - Successfully moved file from /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-fanart.jpg to /Volumes/BD CINE 123/Desconexion (2012)/Desconexion (2012) [V.O].Blu-ray-fanart.jpg
2017-09-28 07:39:13,362 INFO [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:1282 - copy file /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-poster.jpg to /Volumes/BD CINE 123/Desconexion (2012)/Desconexion (2012) [V.O].Blu-ray-poster.jpg
2017-09-28 07:39:13,362 DEBUG [tmmpool-rename-T1] org.tinymediamanager.core.Utils:839 - try to copy file /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-poster.jpg to /Volumes/BD CINE 123/Desconexion (2012)/Desconexion (2012) [V.O].Blu-ray-poster.jpg
2017-09-28 07:39:13,369 INFO [tmmpool-rename-T1] org.tinymediamanager.core.Utils:887 - Successfully moved file from /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray-poster.jpg to /Volumes/BD CINE 123/Desconexion (2012)/Desconexion (2012) [V.O].Blu-ray-poster.jpg
2017-09-28 07:39:13,371 INFO [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:1282 - copy file /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray.nfo to /Volumes/BD CINE 123/Desconexion (2012)/Desconexion (2012) [V.O].Blu-ray.nfo
2017-09-28 07:39:13,371 DEBUG [tmmpool-rename-T1] org.tinymediamanager.core.Utils:839 - try to copy file /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray.nfo to /Volumes/BD CINE 123/Desconexion (2012)/Desconexion (2012) [V.O].Blu-ray.nfo
2017-09-28 07:39:13,373 INFO [tmmpool-rename-T1] org.tinymediamanager.core.Utils:887 - Successfully moved file from /Volumes/BD CINE 123/Desconexión (2012)/Desconexion (2012) [V.O].Blu-ray.nfo to /Volumes/BD CINE 123/Desconexion (2012)/Desconexion (2012) [V.O].Blu-ray.nfo
2017-09-28 07:39:13,374 INFO [tmmpool-rename-T1] o.t.core.movie.MovieRenamer:1282 - copy file /Volumes/BD CINE 123/Desconexión (2012)/extras/Desconexion 1080p [tt1433811].mkv to /Volumes/BD CINE 123/Desconexion (2012)/extras/Desconexion 1080p [tt1433811].mkv
2017-09-28 07:39:13,374 DEBUG [tmmpool-rename-T1] org.tinymediamanager.core.Utils:839 - try to copy file /Volumes/BD CINE 123/Desconexión (2012)/extras/Desconexion 1080p [tt1433811].mkv to /Volumes/BD CINE 123/Desconexion (2012)/extras/Desconexion 1080p [tt1433811].mkv
