2017-09-19, 14:15
KODI 17.X recording without backend?
Hi, I have a question about the KODI 17.X system.
Really needs a multiple answer.
I use LIVE IPTV whit own url from a live provider for TV channels
To view those channels, most of us use ( PVR Simple client) uses.
Many also use backends to record programs, such as TVheadend DVBserver link etc.
What I have as question is!
Can you record live ip tv streams, WITHOUT BACKEND direcly into kodi, and still have the same functionality as simple client, whit epg.
With simple client, (- recording, time shift, etc. does not work.)
I figure if this exist.
The installation should be as in a simple client, and then it's only to record. Therefore, I do not want to use a backend server, but have it directly in Kodi.
Why? I do not have any computer I can save as server, nas or similar.
I run kodi directly on an android tv with all kodi features, and no, I'd prefer to avoid android apps because all apps are not available to android tv's in google play.
I find no PVR client or addon so far that can act this way, searched and searched but finds none. Also searched for longer.
(So what i need is a PVR simple client whit IP LIVE Tv function and record function that saves on usb drive whit EPG, and if it exist, timeshift) thats about it
