Full Version: TouchPoint selects wrong line in PVR guide
Tested on:
  • Samsung Galaxy Tab S2
  • Samsung Galaxy Tab S3
Skin:
  • Estouchy
Kodi Versions:
  • Kodi 17.x (every version)
  • Kodi 18.x Alpha
Bug-Description:
If you touch a show in PVR guide, always the show on the upper line is selected
thnx for the report!
i can confirm the issue. will look into it.
(2017-09-20, 22:58)ronie Wrote: [ -> ]thnx for the report!
Thank you very much!
will be fixed in the next release.
https://github.com/xbmc/xbmc/pull/12815/
Perfect! Is the fix for Kodi 17 or 18 or both?
for 18 at least, not 100% sure if there's going to be another v17 release.
if you feel adventurous, it is simply removing one line from ViewsPVR.xml
https://github.com/xbmc/xbmc/pull/12815/...dc042dL194
(2017-09-21, 01:36)ronie Wrote: [ -> ]for 18 at least, not 100% sure if there's going to be another v17 release.
for 18 will be perfect! I already use this version, because it is right now very stable and IMHO it would already be already a beta! ;-)
it would be very nice if you could take a look at this tread, since the bug still exist: Text labels disapper if profile screen is used on non standard skin (Estuary), e.g. Estouchy
Thread closed, bug fixed in current nightlies! Thank you very much, Ronie! :-)
