Hi guys,
I'm having a really weird problem. I'm missing one channel from my TVH backend. When using TVHClient on my phone and the iPad client, it works just fine. But KODI doesn't pick it up even though it says:
PVRBackend
But going to the channel manager:
ChannelManager
So what's going on here? All other clients see all of the 57 channels just fine.(same user is used)
Can you actually play the channel in other clients?
Kodi does seperate Radio an TV channels, maybe it's incorrect listed as Radio?
Yes, the tv channel is available to stream for other clients. It's not mislabeled as Radio as it's seen in the system information/PVR Backend in kodi as a TV-Channel(57) but under ChannelManager there are only 56 available..
Is there guide information for the channel? Have you kept the setting on which hides channels that have no guide information?
Yes, there is guide information for the channel
I did a clean re-install of a Kodi client on Windows that i have for test purposes, it too didn't have the channel.
First i did a upgrade to 18 beta to see, but that didn't fix it, then i uninstalled and re-installed 17.4.
The channel did re-appear afterwards. I'd rather not have to reinstall the many RPi and Vero clients i have lying around the house so i'm not sure what has to be re-set to be able to see it again.
I have to do some digging.
Have you tried resetting the PVR data, or just resetting the Tv and Epg databases?
Just the databases, how can i reset the pvr data? remove/Reinstall of the TVH PVR client?
I have a similar issue, although in my case I have 18 channels in TVH and only 3 show up in Kodi.
I turned on logging, and I see them all logged from pvr.hts:
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:32869369, name:COZI
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:138104517, name:ABC
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:268348787, name:NBC
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:299130237, name:LAFF
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:442631668, name:WB
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:588238615, name:Fox 7
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:695981251, name:Justice Network
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:771170826, nameBS
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:794073728, name:ION
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:853812569, name:MeTV
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:1016288178, name:KBVO
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:1269261366, name:Escape
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:1395876717, name:KLRU-Q
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:1454846592, name:GRIT
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:1608745083, name:Create
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:1874426606, name:Buzzr
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:1921235088, name:CBS
19:52:44.987 T:140484850468608 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - channel added id:1943309678, name:Movies!
But then a little later in the log files the only thing showing up in PVRChannelGroup is these three:
19:52:54.976 T:140484588582656 DEBUG: PVRChannelGroup - Load - 3 channels added from clients to group 'All channels'
19:52:54.976 T:140484588582656 DEBUG: CPVRChannelGroups - LoadUserDefinedChannelGroups - 1 new user defined TV channel groups fetched from clients
19:52:54.976 T:140484588582656 DEBUG: PVRChannelGroup - Load - 0 channels loaded from the database for group 'TV channels'
19:52:54.976 T:140484588582656 DEBUG: PVR - GetChannelGroupMembers - get group members for group 'TV channels' from add-on 'Tvheadend:127.0.0.1:9982'
19:52:54.976 T:140484588582656 INFO: PVRChannelGroup - AddAndUpdateChannels - added TV channel 'ABC' at position 24 in group 'TV channels'
19:52:54.976 T:140484588582656 INFO: PVRChannelGroup - AddAndUpdateChannels - added TV channel 'WB' at position 54 in group 'TV channels'
19:52:54.976 T:140484588582656 INFO: PVRChannelGroup - AddAndUpdateChannels - added TV channel 'PBS' at position 18 in group 'TV channels'
19:52:54.976 T:140484588582656 DEBUG: CPVRChannelGroup - Persist - persisting channel group 'TV channels' with 3 channels
19:52:55.115 T:140484588582656 DEBUG: PVRChannelGroup - Load - 3 channels added from clients to group 'TV channels'
This is with Kodi 2.17.4, tvheadend 4.2.4, and pvr.hts 3.4.27.
I also have same problem on android and windows with kodi 17.6 and all versions of 18 for me 1 channel is missing
