Full Version: Python wont run after I set video to a normal mode
Hi all,
I need some help with getting the python code to work after when I set the video to a full screen mode.I have a trouble with calling onAction function, when I pressed on the enter button it will start to play the video stream and when I pressed on the enter button again it will set the video to a full screen mode as it will be calling onAction function without have any problem. When I pressed on the backspace button, it will set the video to a normal screen mode but it won't be calling onAction function unless when I have to press backspace button again.
If I don't set the video to a full screen just a normal video mode, I can be able to call onAction function without have any problem when I press on the up, down, left, right arrow and backspace buttons of the keyboard. I can't be able to find out why it would not let me to call onAction function when I set the video to full screen mode and then set the video to a normal screen mode when I pressed on the backspace button. I think something have to do with video control issue but I am not too sure why.
I am using videowindows control on my skinning so I can watch the small video by using this:
<control type="videowindow">
      <posx>822</posx>
      <posy>45</posy>
      <width>432</width>
      <height>225</height>
      <animation type="Conditional" condition="!Control.IsVisible(389)">
          <effect type="zoom" end="100" center="822,45" time="500" />
       </animation>
</control>
Here is the code that I use to run on python:
def playStreamUrl(self):
   print "you are calling playStreamUrl...................................."
   FullScreen = ADDON.getSetting('FullScreen.enabled') == 'true'
   if ! self.player.isPlaying():
      if FullScreen == False:
          self.player.play(item = stream_url, windowed = True)
          isPlaying = True
          xbmc.executebuiltin("xbmc.ActivateWindow('video')")
          ADDON.setSetting('FullScreen.enabled', 'false')
   else:
         xbmc.executebuiltin("Action(Fullscreen)")
         ADDON.setSetting('FullScreen.enabled', 'true')
         self.getControl(1).setVisible(False)
def onAction(self, action):
   print "you are calling onAction...................................."
   if action == ACTION_BACKSPACE:
      print "ACTION_BACKSPACE.......................passed 1"
      if allchannels_enabled == 'true':
         print "ACTION_BACKSPACE passed ......................................1"
         if self.player.isPlaying():
               self.getControl(1).setVisible(True)
   if action == ACTION_ENTER:
      if allchannels_enabled:
         if self.channels_Index != len(self.program_buttons) - 1:
            self.playStreamUrl()
How I can be able to call onAction function when I set the video to a full screen mode and then set to a normal screen mode?
Do I need to create a custom video windows so I could be able to call onAction function or what?
