Full Version: tvOS 11 Install Issues
Hey Everyone,
I've installed Kodi on the Apple TV 4's a few times before but right now but I'm having some problems with 17.4. My guess is it's just a problem on my end as I don't see anyone else having this issue on the forums. I'm not sure what I'm doing wrong though.
Basically when I try to install it via xcode devices it says "There was an internal API error.". If I look at the logs below I see the following.
I'm able to push apps to the device no problem via xcode (dev cert and same provisioning profile).
This is a paid developer account if that helps.
"This app was not built to support this device family" looks like my problem but I'm not sure why I would be seeing that.
Any ideas?
Thanks!!
Sep 23 11:10:45 Living-Room installd(MobileSystemServices)[43] <Notice>: 0x16f877000 -[MIClientConnection installURL:withOptions:completion:]: Running installation as QOS_CLASS_USER_INITIATED
Sep 23 11:10:45 Living-Room installd(MobileSystemServices)[43] <Notice>: 0x16f903000 -[MIClientConnection _doInstallationForURL:withOptions:completion:]: Install of "/var/mobile/Media/PublicStaging/kodi-20170922-fa09db5-Krypton-ios.ipa" type Customer (LSInstallType = (null)) requested by lsd (pid 72)
Sep 23 11:10:47 Living-Room assertiond[59] <Notice>: Request to create termination assertion <BKSTerminationAssertionCreateEvent: 0x10be2c4d0; Identifier: 43-9CF49344-4453-489B-A237-7A0E80CEC6EB; Name: FBSApplicationTerminationAssertion; Target BundleID: com.company.Kodi; Efficacy: Unconditional> from client <BKClientHandle: 0x10bd28390; installd:43; connections: 1>
Sep 23 11:10:47 Living-Room assertiond[59] <Notice>: Acquisition success for assertion <private>: <private>
Sep 23 11:10:47 Living-Room installd(AssertionServices)[43] <Notice>: Acquired termination assertion for event <BKSTerminationAssertionCreateEvent: 0x1009721c0; Identifier: 43-9CF49344-4453-489B-A237-7A0E80CEC6EB; Name: FBSApplicationTerminationAssertion; Target BundleID: com.company.Kodi; Efficacy: Unconditional>
Sep 23 11:10:47 Living-Room installd(MobileSystemServices)[43] <Notice>: 0x16f903000 -[MIInstaller performInstallationWithError:]: Installing <MIInstallableBundle ID=com.company.Kodi; Version=1.0, ShortVersion=(null)>
Sep 23 11:10:47 Living-Room installd(MobileInstallation)[43] <Notice>: com.company.Kodi:7:5:1:1:Start : Install (New)
Sep 23 11:10:47 Living-Room installd(MobileSystemServices)[43] <Notice>: 0x16f903000 -[MIBundle isApplicableToCurrentDeviceFamilyWithError:]: 897: This app was not built to support this device family
Sep 23 11:10:47 Living-Room assertiond[59] <Notice>: Client relinquished <BKTerminationAssertion: 0x10be33a00; "FBSApplicationTerminationAssertion" (Unconditional); 43Sadnull) id:\M-b\M^@\M-&7A0E80CEC6EB>
Sep 23 11:10:47 Living-Room assertiond[59] <Notice>: -[BKAssertion dealloc] - <0x10be33a00>
Sep 23 11:10:47 Living-Room installd(MobileSystemServices)[43] <Notice>: 0x16f903000 -[MIInstaller performInstallationWithError:]: Preflight stage failed
Sep 23 11:10:49 Living-Room PineBoard(PineBoardServices)[46] <Notice>: backboardd user events did idle
Sep 23 11:10:49 Living-Room PineBoard(PineBoardServices)[46] <Notice>: Firing trigger named 'idle-type background tasks'
Sep 23 11:10:49 Living-Room PineBoard(PineBoardServices)[46] <Notice>: Resetting idle timer to 50 seconds (retroactively)
Sep 23 11:10:49 Living-Room dasd(DuetActivitySchedulerDaemon)[89] <Notice>: Trigger: <private> is now [0]
Sep 23 11:10:50 Living-Room installd(MobileInstallation)[43] <Notice>: com.touchblocks.Kodi:7:5:2:0:Fail (End) : Install (New)
Sep 23 11:10:50 Living-Room lsd(MobileInstallation)[72] <Notice>: (null):5:1:2:0:MobileInstallation returned nil for file:///var/mobile/Media/PublicStaging/kodi-20170922-fa09db5-Krypton-ios.ipa/
Sep 23 11:10:50 Living-Room mobile_installation_proxy(MobileInstallation)[287] <Notice>: (null):5:1:2:0:_LSInstallationManager install:withError finished
Sep 23 11:10:50 Living-Room mobile_installation_proxy(MobileSystemServices)[287] <Notice>: 0x16fc37000 handle_install: Installation failed: Error Domain=MIInstallerErrorDomain Code=10 "This app was not built to support this device family" UserInfo={LegacyErrorString=DeviceFamilyNotSupported, FunctionName=-[MIBundle isApplicableToCurrentDeviceFamilyWithError:], SourceFileLine=897, NSLocalizedDescription=This app was not built to support this device family}
Installing the iOS version on an Apple TV 4 won't work.
You have to use the build for the Apple TV which is currently http://mirrors.kodi.tv/test-builds/darwi...--tvos.deb
