2017-09-24, 15:51
2017-09-24, 16:18
Go to addons > my addons > PVR clients . You should find all of them (including IPTV Simple) the, installed but disabled.
Just right click/long press, then information and enable. Then it should be available and operational.
2017-09-25, 00:30
No, there is no PVR clients installed: TV > browser > no list appears!
2017-09-25, 03:17
Where did you get your kodi from? All official android releases have the pvr clients included, but some box sellers illegally redistriute a different version with added addons and the pvr clients removed.
My best advice: remove the kodi version you bought with the box and install from the play store or the apk from our download page.
2017-09-25, 09:20
Tanks.
Tv box is: R-TV BOX S10 KODI 17.4 DDR4 3GB eMMC 32GB Android 7.1.2 4K TV Box S912 AC WIFI Gigabit LAN Bluetooth 4.1 by Geekbuying
2017-09-25, 10:33
This one - https://www.geekbuying.com/item/R-TV-BOX...81393.html ?
It's got their own fork of Kodi on it (KDMC), so who knows. You'd be best off asking them, or whoever you got the box from.
2017-09-25, 14:32
Yes it is that.
2017-10-21, 18:48
Hello everyone,
I have Kodi installed on my VuSolo SE (Linux based). Attempting to install a m3u list, I searched for PVR clients. Kodi shows no PVR clients. Everything else is there, but no PVR.
Does anyone have a clue? Thanks in advance.
Ronaldini
Ronaldini
2017-10-21, 19:05
For Linux you need to install them seperately via apt-get.
2017-10-23, 07:49
Actually that depends what flavour of linux you have...
2017-11-14, 04:21
That has happened to me i found out by reinstalling kodi it showed up and yes flavour of linux you have makes a diffrence
