Playback stops randomly - Shield
Does this log of it happening give any indication as to why?
SMB/Shared mysql db. From what I can gather it is not the network.
https://pastebin.com/QamGVbgU
Without a proper
debug log, there is nothing to investigate.
Apologies - forgot the paste.
I have changed an Ethernet cable run, tried eliminating switches, tried wifi, reset the shield and it keeps on cutting out every so often. I did not try anything with the server which is windows 10 as all other devices don't have the issue.
On recomendation of nvidia forums i tried spmc and it has not cut out once. Yay.
In conclusion there is some issue with kodi plus shield plus smb shares plus mysql.
I just got a Shield and have the same issue with Kodi 17.6. Anything else that can be done?
SPMC still going strong here, the 17.6 version.
If you dont want to use that you could try the alpha Leia Kodi builds, I have not tried them yet, too many devices using the sql db to be bothered with db mismatches.
