2017-09-26, 09:48
Hi.
I hope this is the proper way of requesting a paid change request. If it is not, then please give me feedback to where to place this request.
We are looking for someone to help us solve a problem with Kodi and are willing to pay for someone to do this for us. We need this solved quickly and any change done must be offered back to the code base of Kodi.
We have a setup where we use Kodi on Raspberry PI with pvr.ip-tv-simple. We use it with a channel list configured in pvr-ip-tv-simple and have attached a IR remote to it. (Making it a set top box) This works fine when everything is in order, but we have encountered a problematic scenario that we want to solve.
The problem we encounter can be reproduced like this:
1. Start playing a channel.
2. Remove ethernet plug from PI
3. Change channel
4. Insert ethernet plug into PI
Kodi is now in such a state that you have to attach a keyboard and press enter to make it stream again. This is a big problem as we want this to be operated by a remote that are limited in capability (we only want to be able to control the channels up and down)
What we need to be able to configure Kodi in such a state that this cannot happen or that sending the changing channel command will restart the playing in full screen mode. The solution must either be a properly configured kodi or a patched install of Kodi - in the last case the end product must be in the form of a updated Kodi package so we can easily distribute this to our Rasberry PI's.
If you are interested in this offer or have any other questions then please contact me.
Edit: Trying to explain the problem in more detail.
The playback of kodi can be in a list view where you see the channels and you can navigate in the channels to select a channel. Do start playing one of the channels here you have to push enter to start playing the stream. It seems that it goes into this state of selecting channels if you try to switch channels when there is no network available. To start the playback again, you must select that the channel should start playing again.
3. Change channel
