Hi all,
First of all thanks for all of the great support here on the forum.
Been a passive user for years.
I am having an issue with SPMC 17.X.
It doesn't add all of my TV Shows to the library for some reason.
In Kodi 17 all of my TV shows are in the library.
Can someone figure out what is going on?
Setup:
Synology NAS & NVIDIA Shield TV 2015 experience 5.2
Thanks in advance!
/Peter
9 out of 10 times, incorrect filenaming is the cause for movies/tvshows not being scraped into the video library.
Please provide a full debug log via pastebin.com , and we can have a look at where things might go wrong.
Hi Klojum,
Thanks for the fast response.
I am at work at the moment and is therefore unable to provide a log.
I will do so when I get home.
My TV shows should all be following the correct naming and structure convention presented in the wiki.
A concrete example of a show I can find in Kodi but not in SPMC is as follows:
"TV Shows > The Americans (2013) > Season 5 > The.Americans.2013.S05E01.Sonarr.WEBDL-1080p.mp4"
(2017-09-28, 14:47)phatass Wrote: [ -> ]"TV Shows > The Americans (2013) > Season 5 > The.Americans.2013.S05E01.Sonarr.WEBDL-1080p.mp4"
Are you using nfo files created with Sonarr. If yes, then Sonarr nfo files are not fully compatible with Kodi.
A quick search in the forum will reveal Sonarr nfo's are problematic. Try Tiny Media Manager or Ember, both in this forum.
It's a the version of Spmc that your usibg that's causing the problem. The new alpha v11 fixes the problem.
V8 worked fine but v9 and v10 are the ones where this issue was encountered.
Hers the link to alpha 11. Download and install this and try it.
https://github.com/koying/SPMC/issues/936
