Full Version: Kodi Forum : Report forum issues here
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
I'm running Windows 10 x64 with the latest version of Google Chrome for desktop.  The new form and even the Kodi.tv home page are detected and displayed in Mobile device mode.  Anyway to fix this so I can view the forum in desktop mode?
(2017-10-09, 15:39)Milhouse Wrote: [ -> ]Also, the "Unsubcribe from this thread" icon is the RSS icon which doesn't seem to be very intuitive/appropriate:
should be better now.
Thanks Ronie!
(2017-10-08, 04:52)wrxtasy Wrote: [ -> ]Issues:
1) Bullet Points Not displaying at all:
should be fixed, though might take a while for it to show up due to css caching server-side
(2017-10-09, 21:01)Karellen Wrote: [ -> ]Request to remove red thread icons.
1. Distracting and makes page look busy and messy
2. Gives the impression there are new posts in that thread, but that only applies to green icons
3. Would not consider threads with 2  or 3 posts "Hot Topics". Would rather use Post Count and Page Numbers to gauge what is a Hot Topic
https://ibb.co/nbUpBG
done. might take a while before the results will be visible.
hi is there a way to change the forums skin color  theme, is to bright for my eyes really hard to read for more than 15 min
thanks
^^ Thread merged.
@ronie,
The fix has come through. So much better. Thank you Smile
Typo in User Profile page - Thanks Given: | Received: - "Received" is misspelled.
Rendering issue in User Profile page - may be limited to banned/spammer accounts, as that's where I've seen it - could be that the text in the blue box is simply too large for the containing element.
Apparent on at least Chrome and FF on Linux and Windows, so appears universal.
EDIT
Poking around in the CSS, it looks like there are a couple of absolute attributed set for class "legend". Taking these away allows the containing box to re-size and centre properly:
(2017-10-10, 10:45)Prof Yaffle Wrote: [ -> ]Typo in User Profile page - Thanks Given: | Received: - "Received" is misspelled.
fixed
Report Post
Text is outside the display box and difficult to read.
https://ibb.co/egUq1G
(2017-10-06, 18:35)Namerp Wrote: [ -> ]- maximise editor window creates unexpected results (chrome) -> no buttons anymore
fixed. might take a bit before the result is visible, due to css caching.
(2017-10-08, 19:24)wrxtasy Wrote: [ -> ]Thx. Found it. What a completely un-intuitive labelled button.
changed it to something more suitable
All embedded images have an ugly border around them at the moment.
(2017-10-10, 12:15)docwra Wrote: [ -> ]All embedded images have an ugly border around them at the moment.
fixed. change will be visible once the css cache expires.
