2017-10-12, 16:42
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
2017-10-12, 16:44
(2017-10-12, 16:30)Milhouse Wrote: [ -> ]Thanks for trying - maybe the social media links could go in the Kodi top bar? Frankly I don't care for them at all, but maybe that's just me - I'm not a teenager!
My thoughts exactly! There is some empty real estate between the 'More' menu and the username though.
(2017-10-12, 16:30)Milhouse Wrote: [ -> ]I'm also seeing the issue reported by DarrenHill, particularly when previewing a new post:
I guess this is not unique to any particular browser or OS as I am seeing it too.
2017-10-12, 18:03
(2017-10-12, 16:42)nIGhT-SoN Wrote: [ -> ]I have this kind of problem when viewing posts:
Using Firefox 56.0 (64bit) on Windows 10 1703 64bit
I can confirm this, I'm getting exactly the same on Safari 11.0 Mac OS Sierra 10.12.6
2017-10-12, 22:46
(2017-10-12, 14:31)DarrenHill Wrote: [ -> ]Hmm, the width tweaks seem to have gone weird (or I've got a partially cached mix of adjustments or something) as now the main text boxes are over the top of the right hand part of the user information part of each post (the avatar, name and information bit) and are displaced downwards as well as a result.
Sorry, my bad!
Changing stuff on-the-fly leads to unexpected results.
2017-10-12, 23:14
(2017-10-12, 10:06)DarrenHill Wrote: [ -> ](2017-10-12, 09:36)jurialmunkey Wrote: [ -> ]Am I missing something really obvious, or is there no way to disable the email function?
I would prefer that users not be able to email me.
Account options (your username in the top-right corner of the screen) > user control panel > click the cog on the left hand side > edit options (last entry in the 2nd section, your profile) > messaging and notifications section on the right hand side of the menu screen.
You can hide your email address there, and also set/unset receiving emails from administrators
Thanks, I was tearing my hair trying to find the options.
I looked in user control panel so many times but I totally missed the cog.
Feels really out of the way - surely "edit options" and "change avatar" should be put in the drop down account options. I find it odd that most of the options/settings are in that menu except for those two.
2017-10-12, 23:17
2017-10-12, 23:36
(2017-10-07, 22:59)Karellen Wrote: [ -> ]When using mobile view, there is no indication of which sub-forums have new threads/posts.
should be fixed.
2017-10-13, 00:47
(2017-10-09, 12:08)docwra Wrote: [ -> ]Subscribed threads do not go bold if they are unread and have new posts.
should be fixed once the css cache expires
2017-10-13, 00:48
(2017-10-07, 10:04)Milhouse Wrote: [ -> ]In my subscriptions list I see the "go to first unread post" circle next to all of my subscribed threads with posts dating from before the upgrade (ie. 28 Sep). Since I'm sure I've already read these threads I tried the "mark forum as read" button at the bottom of the forum, it says it's marking all forums as read, but when I refresh my subscriptions page the "go to first unread post" circles are still present - maybe the "mark forum as read" button isn't working? If I click on a circle for one of my subscriptions and then refresh the subscription list the circle will be gone (as the thread is now "read") so it doesn't seem to be a bug in the subscriptions list.
Edit: Hmmm, maybe the bug IS with the subscription list:
This is my list of subcsribed threads AFTER clicking "Mark forum as read":
Notice the "(->)" newpost circle next to "Intel VAAPI VC-1 Monoblocking RCA resolution" at the bottom of the image.
Here is the same thread, viewed directly in it's Linux & Live support sub-forum:
where the "(->)" newpost circle is not present, so why is my subscribed list indicating this thread has unread posts?
tested with the default mybb theme and it behaves the same.
i'm afraid it's not something we can fix. it must be a mybb feature or bug.
2017-10-13, 00:55
(2017-10-06, 10:07)DaveBlake Wrote: [ -> ]Getting funnies with the header layout, see top right where the user drop down should be
i can't reproduce this, is it still a problem?
if so, which os / browser?
2017-10-13, 03:34
(2017-10-07, 16:08)natethomas Wrote: [ -> ]The new mobile forum is better, but I think the extras take up too much space. It’d be nice if all the info about the post author took up one or two lines, rather than approximately 15 lines. It makes for the strange situation where each post is typically quite a bit shorter than the info about the post author.
should be better now: before / after
2017-10-13, 04:52
I thought this one was already listed *somewhere* but I scanned the topic and I cannot find it. Keelhaul me if I overlooked it.
When a visitor is not logged in, the main page template is not filled in with the correct data.
Quote:Users online:
Please welcome our newest member, Wiruke
{1} {2} active in the past {3} minutes ({4} {5}, {6} of whom {7} invisible, and {8} {9}).
2017-10-13, 05:55
(2017-10-13, 00:55)ronie Wrote: [ -> ]Mine is the same, you can click on the little bit that peeks out from under the banner and get your user settings.(2017-10-06, 10:07)DaveBlake Wrote: [ -> ]Getting funnies with the header layout, see top right where the user drop down should be
2017-10-13, 06:35
2017-10-13, 09:14
(2017-10-13, 00:55)ronie Wrote: [ -> ]@ronie Win 10 Firefox v 56.0(2017-10-06, 10:07)DaveBlake Wrote: [ -> ]Getting funnies with the header layout, see top right where the user drop down should bei can't reproduce this, is it still a problem?
It is related to window width, if I widen sufficiently then it looks OK
