Full Version: Kodi Forum : Report forum issues here
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
Is there a way to turn off, or hide, the mega menu that now appears above subscribed threads?
There are currently two font sizes for text links. The one created by the [url] tag is slightly smaller than normal.
Does anyone else have problems logging in with Tapatalk on android?
"You have entered an invalid user name/password combination."
I double checked and made sure I inserted username and password correctly.
I can log in with the same combination on my PC, no issues.
(2017-11-02, 12:54)fijasko Wrote: [ -> ]Does anyone else have problems logging in with Tapatalk on android?
No issues logging in... just can't use it for replies.
For IOS tapatalk works fine. Wink
Starting to wonder if I imagined it, but a few days ago I'm sure that when you "Full Edit"ed a post you were positioned at the top of of the post - this was a change from how it used to be when the new forum first went live, as you'd be positioned at the end of the post, and now in the last few days it's reverted to this "end of post" positioning.
I preferred the start-from-top editing position, not sure how others feel about this, and whether it can be changed (possibly, again)? Smile
Has the ability to "Mark all read" been removed?
Also, I find the entire design hard on my eyes; too much white space and all the colours are too similar.
(2017-11-04, 00:46)mdh99 Wrote: [ -> ]Has the ability to "Mark all read" been removed?
it's the little checkmark icon at the bottom of the forum index page.
(2017-11-04, 01:05)ronie Wrote: [ -> ]
Can it be added to https://forum.kodi.tv/usercp.php?action=subscriptions it's the first page I hit.
Not possible to go a level up/back if browsing via mobile
As example if ur in a WIP Skin tread there is no way to go back to the treadvoverview and from there no way back to "Skinning"
Please (would be nice if u guies) fix this, as this makes the whole Forum almost unusable on a smartphone!
Would be nice to, if there would be a not so green theme
+postheaders r still bit to big from my point of view, guess the whole mobile view needs still some adjustment.
(2017-10-31, 21:21)DarrenHill Wrote: [ -> ]The user search on the profile editor page in the moderator control panel also doesn't work (although the one in the members list under the "more" dropdown list does work).
think that's already fixed? could you retry?
(2017-10-27, 04:37)jurialmunkey Wrote: [ -> ]The bar in private messages that shows how much space is used doesn't appear to be working. More than 80% of my PM space is used, but the bar is only showing about 10% used.
should be fixed. mind testing it?
(2017-11-05, 02:06)ronie Wrote: [ -> ]
It's working for me now, thanks @ronie
(2017-11-05, 02:06)ronie Wrote: [ -> ]think that's already fixed? could you retry?
Yup, working now. You can tick that one off the list.
Getting multiple emails for subscribed threads from old posts (couple of days old) - no new posts are in thread so not sure what would be triggering the emails.
