I just spent several hours writing a letter (with references) to a member of Team Kodi concerning GSOC and the Kodi roadmap. When I tried to send it, the forum server said "Private messaging disabled. You cannot send private messages to this user."
-- If sending a private message is not possible, there should be no button in the users profile which says "Send a private message."
thanx for the report!
the button should be gone now if a user has disabled PM's.
Sometimes when I visit the forum it displays a banner notice about cookies at the bottom of the page (the GDPR thing.) If you create a new thread and type a bunch of text, then dismiss this banner just before posting, everything that you typed is lost. This is a trap for the unwary user: the banner should be re-worked to make it non-destructive.
when you're creating a post, the text is auto-saved periodically.
in case you loose what you've had so far, a recover button will show up on the editor, which allows you to restore your post.
(2019-04-15, 21:27)ronie Wrote: [ -> ]when you're creating a post, the text is auto-saved periodically.
I just got hit again with the cookie notice. Fortunately I know about the button now -- but I think nobody would find the button if they did not already know this feature exists. For the sake of good user interface design, the button should be larger, with printing -- like the ones that say "
Preview Post", "
Save as Draft". And it should be a bright color so you cant miss it. Or maybe it should recover automatically.
