2017-10-10, 03:17
I installed Kodi v.18 x64 and Titan for it both under development.
I've read of vertical menu problems. I too had it. Select any vertical menu option and Kodi immediately closed. I kept persisting without changing anything. After about the 6th attempt, it 'took' without crashing. Vertical menu confluence style large with custom menu and submenu is in place and navigates as intended through many open and close of Kodi to be sure it 'took'.
I noticed when installing Titan for Leia, many dependencies failed. I was persistent with this too. After the 2nd attempt I turned off my VPN. Then all the dependencies installed. Can't explain this, just how it went......
I do notice even though dependencies installed ok, navigating to most of them to 'configure' reveals blank settings pages. Most dependencies I have always used default values anyway. Any I changed in the past were minor adjustments with very little affect on the 'big picture' of things. A major one (for me) was the inability to use Yahoo Weather. There is no field to config or enter my zip code or anything else. It's all blank. So, I switch to estuary and then I can config. As a matter of fact, most of the add-ons can be configured using estuary but none with Titan. Some have a greyed out 'configure'. So I can config everything that can using estuary and then switch to Titan when finished. Solved, sort of.
I'd like to backup the config except the add-on is blank and doesn't appear in estuary since it's a Titan skin feature only. Where is the default location the backup is created to?
Also, language flags do not appear in the library and they didn't in the previous version I used either.
All the functions I normally use seem to be working fine (except those listed above) upgrading from Kodi v.17 x32 and Titan Krypton to Kodi v.18 x64 and Titan Leia. Just wanted to give some feedback. Overall I'm happy enough with the results to use everything as my daily driver unless I run into a roadblock I'm unaware of at this time. (Windows 10 2nd Creators Update is due in a week) Thank you for the development of your continued contribution. Looking forward to updates in the future preparing for Leia especially x64 version. Astonished everything is working as well as they are (even now) tbh.
