I'm sure this is not said enough, but users like me really appreciate what you developers do.. Thanks again..
its working for me i get 5.1 out on my pioneer AV receiver, im using the onboard soundcard on asus extreme striker motherboard.
you earned my respect wiso
Thank you WISo!!!
This version worked great for me. I now have proper AC3 and DTS decoding from MKV sources. I can post a log if you need it.
Here's my setup:
2.4 GHz Core2Duo
Vista Home Premium
Asus P5K-VM with on-board HD Audio
Nvidia 8500GT
I tried some 1080p and some 720p sources. Both played back beautifully. The CPU usage is a little high for 1080p (it can hit 85-95% but averages around 50-65%) but it looks and SOUNDS great!!
Thanks again! I look forward to these test releases!
works great now!!!
can't say how much I appreciate this too!
I tried it with two separate machines...
Dell xps m1330 via hdmi
and and old original P4 2.8ghz and a SB audigy SE 7.1 card via optical
both are vista sp1
I can pretty much use this now full time... I just need to get my mce remote and smb shares workin one way or another, but i'm sure in time they will be supported like the linux version...
thanks for your hard work! no go for me. I also check mplayer, and it works fine for digit sound output (mplayer -ac hwac3), so audio device driver should have no problem.
20:24:12 T:3412 M:2147483647 DEBUG: Checking if window ID 12005 is locked.
20:24:12 T:3412 M:2147483647 DEBUG: Constructing surface 1280x768, shared=00000000, fullscreen=1
20:24:12 T:2100 M:2147483647 ERROR: CWin32DirectSound::CWin32DirectSound - CreateSoundBuffer failed with error code 0x80004001
20:24:12 T:2100 M:2147483647 ERROR: CThread:
taticThread : Access violation at 0x0041903d: Reading location 0x00000000
20:24:12 T:2100 M:2147483647 NOTICE: Closing audio device
taticThread : Access violation at 0x00418f32: Reading location 0x00000000
20:24:12 T:2100 M:2147483647 DEBUG: CThread:
taticThread, deleting thread graphic context
20:24:12 T:2100 M:2147483647 DEBUG: Thread 2100 terminating
For those who has problems. Try setting audio output default to spdif in windows and see if that helps.
kouros Wrote:For those who has problems. Try setting audio output default to spdif in windows and see if that helps.
All I have for sound is an optical cable going from my Asus motherboard to my receiver, so I think its already defaulted to this as nothing would work otherwise. When I have time I'll try blowing everythign away and trying again.
Great work wiso and anyone else that helped!
anyo Wrote:I just need to get my mce remote and smb shares workin one way or another, but i'm sure in time they will be supported like the linux version...
SMB should work since a few revision.
jz53 Wrote:20:24:12 T:2100 M:2147483647 ERROR: CWin32DirectSound::CWin32DirectSound - CreateSoundBuffer failed with error code 0x80004001
From the DirectSound error code: 0x80004001 -> DSERR_UNSUPPORTED
Can't really tell why it works then with mplayer. maybe I'll find there something in the source but the coed base is huge...
So!
i found 2 old problems
1. when i highlight "files" i`ve got drive error
2. when i changed subtitles don`t work "NextSubtitle" function and if i did it from OSD menu movie getting faster for sometime and picture and sound is unsyncronised.
Guys! Thanks for ur work!!!!!!
thanks WISO.
ok dilemma, i can see all my shares, I added in a manual ip and then it finds my dns entries. can setup source shares and link to them. I entered in the same ip as the computer that is hosting it.
finds all my music and movies. now when trying to setup movies it freezes. *.vob files.
music scans and setups library, will play an album once then the next time it will cannot play playlist too many errors but no freezing.
will not pickup my userdata folder settings backup or DB's when i overwrite the existing, tried to find an debug rprt fot this but i looked through all instances but no luck for this specific crash. I will read some more today. total noob at this stuff, sorry.
regards,
dvs
I'll try to give this
dxdiag a run when I get home tonight and see what it says.
CrazyIvan
what can say dxdiag for opengl version?
