Full Version: running Kodi (on android box) off 8GB ROM or move to faster MicroSD card?
I have an android box (NEXSMART D32 Android mini pc Support 4K HD TV Android 5.1 Quad-core Cortex A7 ) with 8GB eMMC ROM of installed memory.
However, I have inserted a Sandisk Ultra 16GB MicroSD card to help with kodi streaming.
My question is whether or not I should move the kodi app on to the SD card, or will the ROM storage be enough to process the data?
I have checked on eMMC and it seems ok, but I am concerned that because android OS takes up more than half the 8GB storage already it will cause issues with streams.
Install LibreELEC to a micro sd card or usb. It will boot & run from the card not touching android
https://forum.libreelec.tv/thread/5274-i...r-amlogic/
sorry, just realised this device is Rockchip
(2017-10-11, 19:19)bubblegum57 Wrote: [ -> ]Install LibreELEC to a micro sd card or usb. It will boot & run from the card not touching android
so there is no way to install LibreElec on a Rockchip, only amlogic?
are you sure it's a Rockchip?  It is cortex A7, is that a Rockchip?
(2017-10-11, 20:29)ssjenforcer191 Wrote: [ -> ]are you sure it's a Rockchip?  It is cortex A7, is that a Rockchip?
A quick search of the box shows it as CPU: RK3229. LibreElec has a Rockchip board https://forum.libreelec.tv/board/43-rockchip/ but still looks like a way off from any sort of release
