Full Version: Audio out of sync and video not smooth when using HDMI (since High Sierra?)
I've been successfully using Kodi connected from a MacBook Pro to my projector through HDMI for a long time. Recently it stopped working correctly:
1. audio seems to become more and more out of sync
2. video is no longer smooth. It's choppy and with an uneven speed
I have tried tweaking with all the video options (sync playback, adjust framerate, audio passthrough, etc.) and nothing seems to solved it. I also tried to install the latests Kodi nightly build but nothing changed.
This only happens when I play it through HDMI. If I remove the HDMI cable, both video and audio work fine when I use Kodi in the laptop by itself.
It started happening recently so I imagine it could be related to High Sierra.
When I use VNC the audio works fine but the video is still choppy.
Anyone else is having similar problems? Is this a bug in macOS High Sierra?
Please advise.
Thanks in advance,
Nuno
Let's start with a debug log (wiki) so we get some more details of what goes on when your HDMI cable is plugged in.
Using VNC for watching videos is never a good idea in my opinion.
(2017-10-15, 04:53)Klojum Wrote: [ -> ]Let's start with a debug log (wiki) so we get some more details of what goes on when your HDMI cable is plugged in.
Eventually, I decided to install Kodi on a dedicated RPI3 I had here doing nothing and now everything works fine. So no need to pursue the solution for this mystery. Thanks for your help anyway!
Nuno
