Full Version: Best settings for DVB Viewer PVR plugin on Android (Amazon Fire TV Box)
Just after some advice regarding the best settings for the DVB Viewer PVR client on Krypton 17.4 Android (on an Amazon FireTV Box)...
Do i need to enable transcoding or not within the DVB Viewer PVR client plugin?
What settings do people recommend for DVB Viewer Media Server backend when using Kodi for Android on a FireTV box? IE is *.ts suitable or *.mpg better?
I have the PVR client and Kodi working well, but having some strange issues recently with pixilation / pulsing on certain UK freeview channels. I believe this is probably due to the stream quality on certain channels (544x576) and possibly some issue with codecs / rendering?
Any help appreciated.
i'm using SPMC and Kodi on my ATV4k (1st gen) with 5GHz Wifi (2.4 GHz sucks).
On my backend i use W2K16 Server with DVBViewer Media Server 2.
I haven't made any special settings, since for an HD stream you only need ~20MBps.
Usually you don't need to transcode if your local network is at least 100MBit Only when watching via VPN i use transcode settings in Kodi 18 PVR addon.
BR
