Full Version: My open issues & Feature requests (3.7.xx Beta)
Hi Marcel,
Here are some of the bugs & feature requests that I have collected:
(3.7.63)
B-1) Why the option of "Random Global Movies & TvShows background", which was in the past, doesn't exist anymore in the Global background setting?
Can you please return it back?
B-2) [Bug] When opening for example the "Audio and subtitles settings", the time bar shape remain there.
https://s26.postimg.org/xay2r5m1l/image.png
B-3) [Bug] Sometimes the poster or landscape image of the current fanart outside the window (usually comes from the current widget) is stuck in the menus
https://s26.postimg.org/bvtdksb89/04a.png
https://s26.postimg.org/toexsnsgp/04b.png
B-4) [Bug] There is a glitch of the text from the Tag area in the homescreen widget when the text is long.
https://s26.postimg.org/q4f7xmlll/image.png
B-5) [Bug] When I'm doing Mute, instead of the old mute speaker icon it shows the static volume icon with the current volume level.
https://s26.postimg.org/qnpd40jbt/07a.png
B-6) Why there is no Season ratings in IMDB? There is only for the TV Show and for episodes.
B-7) [Bug] Sometimes the IMDB rating is stuck and show the same rating for all the episodes and seasons inside the TV Show (In the library).
For example: https://s1.postimg.org/5dlc3o5qin/11_a.png
B-8) [Bug] The 'Update Library' process is changing the view mode of the first window that you get into to a List type. Annoying. (Link: 319874 (thread))
B-9) * I don't know if it's a bug regarding to the skin but it seems that it might: Regarding the PVR and LiveTV, the video is freezing for few seconds when stating the playback (Link: 320340 (thread))
B-10) Disable the "Show small seekpanel when video is paused" setting is not working. It still shows it all the time when video is paused.
Requests:
R-1) Add version number in the details in ViewModes like "Square Details" (It was already been done previously, I don't know why it has been disappeared)
https://s1.postimg.org/158a096ogv/image.png
R-2) Add a year next to the title in Movies tags in the Movies library.
R-3) Add an option for adding a date info to the homescreen widget tags (Long time a go it was on your To Do List, but I don't see any new since then)
R-4) Add also ratings for Trakt (In addition to IMDB)
R-5) Add left/right arrows for widgets to present that there are more items horizontally (I think it was on your To Do List)
https://s26.postimg.org/v9uo3ujmh/screenshot017.png
R-6) Please return back the option to set the background from widget number ## (It's totally gone now)
R-7) Replace the 'Chapter XX/YY' text in the small OSD and show the 'Finish at' instead:
Image: https://s1.postimg.org/82ok0w291r/image.png
R-8) Add an option for making a personal order to the View Modes dialog, so I can place all my most use / favorite view modes to be at the top.
Would be nice if a final version for Krypton could be published, which removes all bugs bumps, described by burekas and other users during the past weeks and months.
Will be fixed in next update
will be fixed in next update
I couldn't reproduce this one, maybe I've already fixed this some time ago but it isn't published yet. Please test again when I publish a new version.
Kodi doesn't have any season info, so no ratings at season level
I can't reproduce but I think in this case it's showing the TV Show's rating instead of the episode's.
Does it fix itself if you re-enter the library ?
Can't reproduce. Please test first with default Estuary skin, might not be skin related.
First of all, it's good to see you back here, I'm hope everything is ok.
Second, thanks for your answer and fixes.
Here are my updates regarding the new update (3.7.65)
Open bugs remains: B-8, B-10
Waiting also for answers about the rest requests.
B-1) [Fixed] "Random Global Movies & TvShows background" is back again with all other - OK.
B-2) [Fixed] The time bar shape - Checked, Ok.
B-3) [Hold] If the thumbnails leftovers will be occur again I will update you again, thanks.
B-4) [Hold] Regarding the glitch of the text from the Tag area in the homescreen widget when the text is long. I need an episode with a long name, I will update if it has been actually fixed.
B-5) [Fixed] The Mute icon. Checked - Ok.
B-6) [Answered] There is no Season ratings in kodi.
B-7) [Hold] Sometimes the IMDB rating is stuck in some episodes (In the library) - Can't reproduce it too, if it will happen again I will update. Thanks.
B-8) [Open Bug] The 'Update Library' process is changing the view mode of the first window that you get into to a List type (See additional link in the first post) - I have seen that you couldn't reproduce it. Strange, I reproduce it all the time, maybe it's one of the scrapers or the Trakt sync addon.
B-9) [Open issue - Kodi] The video freezing when minimize-maximize the kodi window (Doesn't happen when switching between windows) - Seems to be a Kodi issue (Additional info: #14 )
B-10) [Open Bug] I think you have missed it: Disable the "Show small seekpanel when video is paused" setting is not working. It still shows it all the time when video is paused.
R-1) [Additional Request] The version number in the "Square details" view mode. - Thanks, but instead of place the version next to the author, can you place the number to be below addon title and above the 'Author'? (When the author is long you can't see the version)
Thanks you, I very appreciates your work. Glad to see you again.
@"marcelveldt"
Status update (Bugs):
B-3) The problem is still existed.
screenshots:
https://s18.postimg.org/fdmu33f4p/03a.png
https://s18.postimg.org/6ilzsnind/03b.png
B-4) Regarding the glitch of the text from the Tag area in the homescreen widget when the text is long. It seems that it has been fixed.
B-7) [Hold] Sometimes the IMDB rating is stuck in some episodes (In the library) - Can't reproduce it too, maybe it has been fixed. If it will happen again I will update. Thanks.
B-8) [Solved] The 'Update Library' process is changing the view mode of the first window that you get into to a List type:
The reason for this explained here: 319874 (thread)
B-10) [Opened Bug] Disable the "Show small seekpanel when video is paused" setting is not working. It still shows it all the time when video is paused.
Opened Requests:
(More details are in the first comment)
[Additional Request] The version number in the "Square details" view mode fixed - But - instead of place the version next to the author, can you place the number to be below addon title and above the 'Author'? (Because when the author is long you can't see the version)
New bug:
B-11) The rating text overlay the 'watched' tags in 'Big List 2' view mode:
Image: https://s18.postimg.org/52ahagiah/image.png
