Full Version: subtile font scaled too short in wide screen
My screen and video resolution set to 1920x1200(Desktop).
UI font looks fine, but video subtitle looks shorter.
I linked a Chinese font(msyh.ttf) to origional skin/subtitle font.The font normally looks nicer with width/height ratio close to 1:1.Wink
Here is someting in the log
UI 1920x1200
Quote:10:44:05 T:1121609440 M:1062187008 DEBUG: Load Scaled size of font /home/chrisyu/XBMC/BUILD/skin/Project Mayhem III/fonts/FrancophilSans.ttf (33.333336): width = 43, height = 45, lineheight = 44
10:44:05 T:1121609440 M:1062187008 DEBUG: Load Scaled size of font /home/chrisyu/XBMC/BUILD/skin/Project Mayhem III/fonts/FrancophilSans.ttf (36.666668): width = 48, height = 49, lineheight = 48
10:44:05 T:1121609440 M:1062187008 DEBUG: Load Scaled size of font /home/chrisyu/XBMC/BUILD/skin/Project Mayhem III/fonts/FrancophilSans.ttf (40.000000): width = 52, height = 53, lineheight = 53
10:44:05 T:1121609440 M:1062187008 DEBUG: Load Scaled size of font /home/chrisyu/XBMC/BUILD/skin/Project Mayhem III/fonts/FrancophilSans.ttf (44.444447): width = 58, height = 59, lineheight = 59
Video 1920x1200
Quote:10:44:13 T:1121609440 M:1011671040 DEBUG: Load Scaled size of font /home/chrisyu/XBMC/BUILD/media/Fonts/msyh.ttf (66.666672): width = 122, height = 88, lineheight = 88
And here is info in 1400x1050
UI 1400x1050
Quote:10:54:21 T:2062034656 M:1047244800 DEBUG: Load Scaled size of font /home/chrisyu/XBMC/BUILD/skin/Project Mayhem III/fonts/FrancophilSans.ttf (25.520834): width = 39, height = 34, lineheight = 34
10:54:21 T:2062034656 M:1047244800 DEBUG: Load Scaled size of font /home/chrisyu/XBMC/BUILD/skin/Project Mayhem III/fonts/FrancophilSans.ttf (29.166668): width = 45, height = 39, lineheight = 39
10:54:21 T:2062034656 M:1047244800 DEBUG: Load Scaled size of font /home/chrisyu/XBMC/BUILD/skin/Project Mayhem III/fonts/FrancophilSans.ttf (30.989584): width = 48, height = 42, lineheight = 41
10:54:21 T:2062034656 M:1047244800 DEBUG: Load Scaled size of font /home/chrisyu/XBMC/BUILD/skin/Project Mayhem III/fonts/FrancophilSans.ttf (34.635418): width = 45, height = 46, lineheight = 46
10:54:21 T:2062034656 M:1047244800 DEBUG: Load Scaled size of font /home/chrisyu/XBMC/BUILD/skin/Project Mayhem III/fonts/FrancophilSans.ttf (34.635418): width = 42, height = 46, lineheight = 46
Video 1400x1050
Quote:10:54:29 T:2062034656 M:1007116288 DEBUG: Load Scaled size of font /home/chrisyu/XBMC/BUILD/media/Fonts/msyh.ttf (58.333336): width = 90, height = 77, lineheight = 77
Should I provide screenshot or something?
It's because your source resolution (I suspect a 4x3 mode) for those modes appear to be the same, and the font is being scaled assuming the output aspect is the same as the source resolution.
Try and find out what video mode (should be in the Debug Log from xbmc) it is loading the skin files from (when in fullscreen and when in the GUI), and what video mode it is using for fullscreen video.
Cheers,
Jonathan
jmarshall Wrote:It's because your source resolution (I suspect a 4x3 mode) for those modes appear to be the same, and the font is being scaled assuming the output aspect is the same as the source resolution.
Cheers,
Jonathan
You mean source resolution is the video file's resolution?
If I was not wrong, almost all my videos are 720p and 1080p, some of them are 4:3. But subtitle font looks like just the same.
About video mode, I don't know where to check. I've paste my log file here.
http://rafb.net/p/boQrmo76.html
Or is there a way to make font width:height=1:1?
Thank you.
Log doesn't tell me what I want unfortunately.
What I meant is the source skin resolution for fullscreen video. The font scaling works by scaling the font so that it matches the screen as if both the source (skin) and destination (screen) resolutions could be displayed on the same screen with everything looking identical.
If the skin resolution is a 4x3 res, it will be stretched to fit on the screen res (16x9-ish) so the fonts will look too wide.
If the skin resolution is a 16x9 res, then no stretching occurs, and the fonts will look correct.
Cheers,
Jonathan
I am using skin Project Mayhem III, 1080i mode(I changed Font.xml in 1080i folder, and it worked).
How could I verify it's 16x9 or 4x3 for sure?
Thank you for your time. Wink
I uploaded 2 pics to show the problem.
UI and video resolution is 1920x1200(Desktop).
Video file is Carnivàle S01E01 HDTVRip 720p x264 FiNE.mkv, VIDEO: [avc1] 1280x720 24bpp 23.976 fps(from mplayer).
I changed the text in subtitle to compare to the UI's.
This one using skin Aeon, cause it has more info while playing.
You can see the fonts in subtitle are shorter than those in playing info area, both Chinese and English.
Same scene with Project Mayhem III.
