2017-10-21, 23:23
I'm sorry if this has been asked before, but I haven't had any luck tracking down the answer.
I'm in the midst of an update / rebuild of Kodi, that I will be putting on several HTPCs throughout the house.
All my movies and tv shows are stored on my QNAP server, and I'm wanting to keep the metadata consistent on all the PCs going forward. To that end, I've started using MediaCenter Master to gather and store the metadata / art in the same folder as the video. I intend to do that for new movies, from now on, which is simple enough, but, for ongoing tv shows, it's not quite so cut and dry, as I'll be adding new episodes, and I don't see a way to update the metadata for the new ones that easily.
My thought was that, after everything was loaded from local information, I would then configure Kodi to use the TVDB scraper, telling to to not wipe the database... and the new episodes would be handled automatically. However, it's not pulling the new info for new episodes like I thought it should / would.
Am I missing something stupid / simple? If I just set it to use TVDB initially, will it pull from the local info files first? Is there a way to configure it to do so?
Any help or suggestions would be appreciated.
