I think it would be a nice feature to have under videos a webcam link so you can make icons for different cams similar to movie covers. That way in the morning traffic cams, surf cams, security cams, etc could be pulled up right on your tv. You can make icons to easily identify each one. Am i the only one who think this woulld be a nice benefit?
could probably easily be done with a script/plugin if you new how to write it you just need to parse the sites they come from
The XBMC-TV script allows you to add your own webcam streams.. Just create an ini file. and place in a directory of your choice and will come up.
Ive added quite a few surf cams that werent listed in my loacl area.
http://code.google.com/p/xbmc-strm-colle...loads/list
