Whilst playing a film it will simply quit and go back to the main menu. I can resume the film and it will play without issue. My source (Windows server next door, ripped MKV files) is on IE not gone into power save etc.
I can replay the same film without issue it just random
Any ideas?
(2017-10-22, 10:30)obwiz Wrote: [ -> ]Whilst playing a film it will simply quit and go back to the main menu. I can resume the film and it will play without issue. My source (Windows server next door, ripped MKV files) is on IE not gone into power save etc.
Any ideas?
how are the movies getting to the player? wifi ? homeplugs?
Could be a network problem, try playing directly from usbĀ
Or try fresh install of Kodi
Thanks for the reply
It's a wired connection, will try with Kodi 17.X as opposed to SPMC to see if that helps
A
debug log (wiki) that captures the problem will help with diagnosis.
