2017-10-22, 14:05
Hi All!
I'm fighting with a problem of audio passthrough in Kodi 17.4 in Ubuntu Linux 16.04.3 LTS.
When linux/kodi is decoding sound evrything is OK, but when I check passthrough option I hear only cracks from speakers, yes they support DD or DTS.
Evrything is working fine in VLC on this system with this options:
I turn on KODI with this parameters:
But I see only this devices (less then in VLC):
And there are settings of passthrough:
Evrything is working fine when the playback device is: Audiotrak ProDigy CUBE, USB Audio Direct #1 hardware device without any conversions
Anybody knew method to force KODI to use this device in ALSA?
On the pulseaudio passthrough isn't working in any app, I have only confiramtion from VNC that passthrough is working with ALSA and device mention before.
Output from aplay -L:
Regs,
Sam!
root@HTPC:~# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
default:CARD=CUBE
Default Audio Device
sysdefault:CARD=CUBE
front:CARD=CUBE,DEV=0
Front speakers
surround21:CARD=CUBE,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=CUBE,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=CUBE,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=CUBE,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=CUBE,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=CUBE,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=CUBE,DEV=0
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=CUBE,DEV=0
Direct sample mixing device
dmix:CARD=CUBE,DEV=1
Audiotrak ProDigy CUBE, USB Audio #1
dsnoop:CARD=CUBE,DEV=0
Direct sample snooping device
dsnoop:CARD=CUBE,DEV=1
hw:CARD=CUBE,DEV=0
Direct hardware device without any conversions
hw:CARD=CUBE,DEV=1
plughw:CARD=CUBE,DEV=0
Hardware device with all software conversions
plughw:CARD=CUBE,DEV=1
a52:CARD=CUBE
Regs,
Sam!
