2017-10-24, 10:00
Hello !
Here is the context :
* I've got a Samsung Smart TV (UE46F6400);
* I've got an Android TV Box (Freebox Mini 4K with a A15 dual-core processor 1,5GHz with 2Go RAM - http://www.universfreebox.com/article/29...ur-1-5-GHz) connected to my TV using HDMI (port HDMI1); I'm using Kodi App from official Play Store with the Plex for Kodi plugin;
I had problem playing video fluently : it seemed to be low framerate.
I've enabled the following options in the player settings :
* http://kodi.wiki/view/Settings/Player/Vi...fresh_rate
* http://kodi.wiki/view/Settings/Player/Vi...to_display
And then the video play perfectly (or near, really better than without those options) !
But... because it must have a "but" :x... the sound is now messy :/. There are "blank space/mute time" (dunno how to tell it in english) for aproximatively 1s each 2s. It seems to be the option "Sync playback to display" which generate the problem. But disabling this option and the video problem is coming back.
How can I fix it according to you, please ?
