Full Version: One specific TV channel does not play right. Nvidia Shield, MediaPortal PVR.
Hello,
Been using Kodi for a couple of years with Mediaportal as backend. This has been working fine but somewhere along the line one specific tv channel started acting up. All other channels are working fine.
This specific channel is  working fine in SPMC with the same mediaportal backend but not in kodi 17.x and kodi 18.x (it might have working in the first versions of 17.x)
I hope that someone can figure out whats going on.
https://pastebin.com/n4HAjAwj
The channel in question is named "DR1 HD"
Regards
Jacob
Looks like you forgot to post a link to the log.
Yeah. I could not figure out how to attach a file so i created a pastebin instead Smile
Regards
Jacob
(2017-10-24, 20:18)mylle Wrote: [ -> ]Yeah. I could not figure out how to attach a file so i created a pastebin instead Smile
Regards
Jacob
Which is the way you're suppose to do it. Wink
Anyone have a clue?
Yeah. Won't work with v17. Please try a v18 nightly and see if opening multiple decoder instances is fixed there correctly for your usecase yet.
Im still having problems. Now with Leia. I now har 2 channels that has no audio.
Here is a link to a recording i did that does not work with sound in Kodi but works fine in VLC
https://drive.google.com/file/d/1GJ6l7HT...sp=sharing
Does Kodi not support LATM?
Regards
Jacob
@fritsch
Could this still be the same issue as you saw in V17?
No one?
Trying one more time. Does anyone know whats going on?
This might be better in the mediaportal section - I'll move it there.
Its not a mediaportal specific issue. Its a front end issue with AAC LATM sound codec i believe.
