The power menu button on Estuary (which I hate) gives the option to reboot from internal in an android device that has both internal and external memory. Is there a way of adding this button to Transparency (which I love)?
You need a button assigned to:
Quote:System.ExecWait("/usr/sbin/rebootfromnand"
The easiest way would be to add that to a submenu or favourite.
If you want it in the power menu you'll need to edit /storage/.kodi/addons/skin.transparency(or whatever the skin id is)/1080p(or720p or xml - wherever all the skin files live)/DialogButtonMenu.xml
Edit: I've no idea how to make that command show up properly - the
at the end should be "; )" (no gap between them). It used to be straightforward to add code here, now god only knows what I'm supposed to do because every time I try I get a blank box.
